Purolator Boss rated at 99% @20 microns (see Mod note in thread text)
Oklahoma
MODERATOR NOTE: the title is misleading as it improperly states the BOSS, but should be Pure One filter.
I reached out via email to find the best oil filter for my truck, and According to Mann+Hummel the Purolator Boss PL22500 is 99% at 20 micron.
No one in the public knows the numbers on the Boss now. It’s a good media by my visual examinations for light spots, comparing Boss to others, use them without worry. I only looked at one Boss because they went to $4 in that size. Very happy what I found, no worries at all. They still may be cheap.
I thought the One spec sheet micron number was higher than they told you, but not using those due to the black glue issue.
A good reason to avoid it then, considering their constant obfuscation.
Seems you’re the only one that doesn’t know….
That’s right everyone else knows and I don’t. I don’t know why you care, you buy PG, but it’s your business to talk how you want. Apparently I lost that right and everyone else still has it. I should be seeing my name on buildings saying this is the only one left who does not comply, find him for the thought changing process.
It's just an odd hill to die on. It's right there in the spec sheet. The thing is rock catcher and they deliberately mislead the consumer.
I'm not sure if there is an argument beyond that, but uh... well there it is.
I still love you 😍 💋
I also buy Pentius and Mobil 1. If I could find the Korean made One for my vehicles I’d buy that too.
When I run out of OEM Honda & OEM Toyota, the " Boss" will be my go to. Doing 3month/ 3K oil and filter anyway. More concerned about flow on my 03' Toyota and 13' CRV. Just my opinion.
