Hello to all.
This is the 4th consecutive UOA on my '05 Pontiac Pursuit. This run started Aug-14-2011 and drained on Mar-11-2012 in my driveway no less as this has been a very mild Canadian 'winter' if I could call it that. The ambition on this run was to take the OLM down to zero and it would have really have been at -1% by the time I actually did the drain. This is a daily driver and sees mostly highway and did approximately 80KM (50miles) per day, but now does 52KM (32.5 miles) per day after my wife changed jobs.
The UOA was performed by Fluid Life but was done by their alternate lab (hence the * beside the lab name on the UOA). They now report VI as well, which was 169 this time around. The lab only reported fuel%, but it actually was better this time with more mileage on this OCI. This may be loosely attributed to the mild winter most likely.
I have refilled with PP (SM) 5W-30 again and put in a Wix 57082 filter. The Napa Gold 7082 looked pretty good when it came out. So I'm sticking with Wix filters. My plan is to run this new sump longer as it will be over spring, summer and fall. Any thoughts/comments on the UOA are very much appreciated.
Regards,
/BTV
Code:
Sample Date Mar 03/11 Aug 14/11 Jan 15/11 June 02/10
Lab Name Fluid Life* Fluid Life Fluid Life FLUID LIFE
Oil PP 5W-30 (SM) FS 5W-30 FS 5W-30 QL Bulk 5W-30
Filter Napa Gold 7082 Napa Gold 7082 Napa Gold 7082 ACD PF456G
Total Miles 63089 miles 55114 miles 48079 miles 41569 miles
Miles on oil 7974 miles 6401 miles 6510 miles 3319 miles
OLM 0% 19% 18% 57%
Make up oil 0 0 0 0
Aluminum....... 2 1 1 0
Chrome......... 1 0 0 0
Iron........... 16 13 24 7
Copper......... 7 6 6 1
Lead........... 0 0 1 0
Tin............ 1 0 0 0
Molybdenum..... 53 48 41 5
Nickel......... 0 0 0 0
Manganese...... n/a n/a n/a n/a
Silver......... 0 0 0 0
Titanium....... 0 0 0 0
Potassium...... 0 0 0 0
Boron.......... 45 99 94 135
Silicon........ 8 9 9 4
Sodium......... 1 1 0 0
Calcium........ 2740 1880 1884 1890
Magnesium...... 11 6 9 11
Phosphorus..... 688 642 662 668
Zinc........... 800 783 782 789
Barium......... 0 0 0 0
Vanadium....... 0 0 0 0
Antimony....... 0 0 0 0
Lithium........ 1 1 1 1
Berylium....... 0 0 0 0
Flashpoint F... n/a n/a n/a n/a
Fuel %......... (1.57) (1.73) (2.03) (1.99)
Antifreeze..... Neg Neg Neg Neg
Water.......... Neg Neg Neg Neg
Insoluables.... n/a n/a n/a n/a
cSt Visc@40C... 55.9 (50.9) (48.6) (46.8)
cSt Visc@100C.. 9.85 (8.88) (8.72) (8.35)
TBN............ 8.23 3.81 3.55 5.69
Regards,
/BTV
Code:
OLM 0% 19% 18% 57%
Make up oil 0 0 0 0
