Ariens Apex 60” ZTMon what?
It feels like LV fluid gets dark really quickly. I'd say you've already reached the point of diminishing returns as you've replaced over 80% of the existing fluid.2013 Ford Escape 2.0T, 107,700 miles
Out: Mercon LV
In: same
3 drain and fills, 12 quarts+ total
The fluid is still not were I’d like it. I need to figure out a cooler line exchange.
I appreciate your comment. I maintain the car for a close friend. I have no experience with Ford transmissions and fluids.It feels like LV fluid gets dark really quickly. I'd say you've already reached the point of diminishing returns as you've replaced over 80% of the existing fluid.
Well done. I would do another service in 1K and see how the fluid looks. FYI, I have had great luck with Valvoline and Castrol CVT fluid in a high mileage Altima.Did the first drain and fill on the wife's 2016 Rogue CVT with 80,000 miles.. the notorious Nissan whine had just started. 4 qts of OE Cvt fluid came out looking like motor oil, filled with 4 qts of bluish green Idemitsu NS3. Hardest part was removing the stupid locking cap. Strange enough, the smell of both fluids reminded me of some sort of cleaning productnothing like traditional ATF, another reason to be weary of universal Atf/Cvt fluid I suppose. Plan on same process every 3rd oil change from here on out, seems smoother after 1 drain and fill.
Mobil 1 ATF is what I used in my 2004 GTO too. I remember being happy with the results.2007 Vette 6 speed manual.....
Out: Well used, but apparently still serviceable ATF...presumably AC Delco, as the service records show mostly dealer service visits.
In: Mobil 1 ATF. I picked up 8 quarts on clearance, I think 4 bucks each. So I have another change in the stash. I'll probably do it again in 15-20k, since it is easy and I have the other 4 quarts.
Same transmission, right? Lots of Vette forum guys recommended it. Clearance pricing was a bonus. But I'm guessing it is being discontinued? Not sure.Mobil 1 ATF is what I used in my 2004 GTO too. I remember being happy with the results.
I think it's different, but that's only because the Vette is a transaxle setup. I know the gearing is shorter on the GTO, but I think it's at least mechanically similar. I've never had a problem with Mobil 1 ATF in GM products.Same transmission, right? Lots of Vette forum guys recommended it. Clearance pricing was a bonus. But I'm guessing it is being discontinued? Not sure.
Took the advice and did a second drain and fill using the Idemitsu, Fluid was much more translucent and less burnt lookingWell done. I would do another service in 1K and see how the fluid looks. FYI, I have had great luck with Valvoline and Castrol CVT fluid in a high mileage Altima.
Put the cap back on 180* out. Hate that thing,
