Ford 6R80 transmission fluid changes
Chennai TN India
So I have a 2018 Endeavour (aka the Everest in Australia, basically a Ranger with a 7 seater SUV body) with a 6R80 transmission (ZF + Ford joint dev right?)
Usage conditions - 60% highway and 40% city (bumper to bumper in Indian tropical conditions) traffic.
Changed the original transmission oil at around 60k miles to a liqui moly "universal" ATF that claimed compatibility with Mercon LV and a laundry list of other european, japanese and american standards that it claims the fluid is "recommended" for.
https://www.liqui-moly.com/en/top-tec-atf-1800-p000243.html
Aisin Warner AW-1, BMW 83 22 0 142 516/83 22 2 152 426/83 22 2 289 720/83 22 2 305 396/83 22 2 305 397/83 22 2 355 599/M-1375.4, Dexron VI, Fiat 9.55550-AV5, Ford Mercon LV, Honda ATF 3.1/DW-1/Typ 3.0, Hyundai SP-IV/SP-IV-RR, Isuzu ATF WSI, JASO 1A-L ...
Now, barely 20k miles down the line, I started to get slippage in the transmission, slight jerks when shifting in low gears and such.
Drained as much of it as I could with a pan drop on a warm engine (a bit more than 6 quarts) and refilled with OE mercon LV from a ford parts store. There was very minor debris on the transmission filter so I cleaned the old filter and reinstalled it.
Now, again something like 25k miles down the line and the same thing is cropping up. I take it this claim of being one size fits all isn't quite accurate and the liqui moly is somewhat too thin for the 6R80. So I've got another 10 quarts of Ford OE mercon LV.
Just do another pan drop, drain and refill, so that more of the really old (factory fill fluid) and maybe not as suitable old (Liqui Moly) drains out, or do I do stuff like disconnecting the transmission cooler lines and draining at least a quart more of old oil out besides the 6+ quarts from a pan drop? I'm getting a new ATF filter this time around.
By the way, I of course refilled the transfer case as well, first with the liqui moly and then with the ford OE.
How many total miles (km) on vehicle? EDIT: got it 60+20+25= 105k miles
Use this to determine how much of the Liqui moly is remaining. Your transmission takes 13.1 quarts (12.4 liters) at full level:
The 6R-80 is very sensitive to fluid type and condition. I suggest installing a drain plug. It is likely you will drain as much as 7 quarts this way. A partial change every 30,000 miles is what worked for me. Always use OEM Ford fluid. The alternatives don't work.
Don't bother with a 'flush' by disconnecting the line. It simply pumps out your new fluid.
One thing you can do is to reset the TCM (transmission control module) properly. It adjusts line pressure and will learn your driving habits. After a reset, do the proper drive cycle. Often helps immensely.
These transmissions are very long lived when maintained carefully. Many of them exceed half a million miles without issue.
We have a similar transmission on a 2014 F150. Did you check for service bulletins and have you had the pan off for cleaning? The magnets do most of the important filtering and Ford added extra magnets because of the trouble they were having. Regardless of how many magnets are in the transmission they will not be effective if they are not cleaned.
I know Ford has some updates / recalls for the 2014 6R80 but don't know about 2018.
OEM fluid is absolutely NOT required or desirable unless it is a "buy it now" deal. The transmissions are sensitive to fluid that is dirty, worn and overheated, not to the brand / label. Keep those magnets clean and monitor your temperatures.
I have some direct experience with the 6r80 in a 2015 Transit 250 van, and a lot of hearsay, so take it for what it’s worth. It sounds like you know at least as much as I do, so reading this is probably doing you no real good, other than encouraging you to keep trying.
It sounds like each time you drain and fill, it improves, but then it gets tired again in 20k-25k miles. So doing another may give you some temporary relief. Here in U.S. some dealers can do a PROPER 100% exchange, which involves working with fluid at very high temperatures (100c?), using a machine that provides that heat; some others will lie and tell you they can, then do some other half-baked or improper flush or drain-fill at the same high dollar.
Personally, I would take a sample now, get it tested, then decide after I got results. If you did 2 back-to-back drain and fills with the 10 qts you have on hand, you should be buying yourself at least another 20-25k miles??? And assuming no warning signs from the analysis, maybe having 10 qts new ( or maybe effectively only ~8 qts since you have to do 2 drains, is enough to neutralize the effects of the remaining factory fill and LM.
And I assume you have figured out how to check the fluid level when it’s all said and done, because Ford made it quite difficult: must be at full temperature and running.
Maybe try Valvoline Restore and Protect ATF
https://sharena21.springcm.com/Publ...3bcc26b5/40f96d44-dab8-f011-b824-9440c99fa601
I've had 3 6R80s since my 2009 F150 (bought in 2011) and the 2015 and 2016 I have now. All have had pan drops and dorman pans installed with drain plugs built in. Each got a new filter with the pan drop and moved the magnets over to the new pan after cleaning them up. Drain and fills after the pan swap for all of them. 330k miles across the three of them and I've never noticed a change in driving after a splash/fill or the pan changes. I've always used actual Mercon LV.
The one difference is the temperatures you are regularly driving in breaking down the fluid faster. I would install a pan with a drain plug and swap fluid every 20-25k miles with original mercon LV and call it good. Just a regular maintenance item I guess.
Yeah thanks, I’m just going to do that. Thanks to import duties Mercon LV retails at near on $13.40 a quart compared to what is it, five bucks stateside. Still, a small price to pay for a trouble free transmission.
I’m just measuring exactly how much old mixed fluid drains out and putting exactly that amount of fresh OE fluid back into the transmission. Hopefully there isn’t any fluid loss - but no way to tell, given it’s all circulating around the transmission.
Changing the filter this time, I’d just cleaned it out the last time around. And I believe drain it when cold and let it drip overnight might get me an additional quart or so drained compared to a pan drop with hot fluid?
I wouldn't worry about dropping the pan again. I would just get a hand or electric pump and suck it out the fill hole. suck it into a container that has gradients to see how much came out and put that much back in. while refilling the last couple of quarts, you do need to run the engine or it just overflows. Then check it with the tiny dipstick to confirm. Drive a bit and do it again if you want.
I have a 6R80 in my 2012 F150 full filter/switch to Amsoil universal ATF LV. I also did the leadframe/reset learning because of drop to 1st gear issues with those years. I also did a service on my daughter's 2015 Expedition. I have been using the Amsoil universal ATF, and universal ATF LV since 1995 with excellent results. I ran 20 qts through each transmission when I switched to Amsoil. I don't know what the percentage of old fluid I have remaing after. But I don't think it is much...... ☺️
That being said I was going to do a line flush, but it is getting really hard to do now days. They say not to on the 6R80. I'm not sure if that is because of the T stat controlling fluid through the transmission cooler. I would either get a pan you can drain, or a vacuum extractor.
Like was mentioned do not shut off the engine while in the process of filling/checking fluid level. Unless you want a transmission fluid shower.......
I would say get the best fluid you can afford. Make sure the transmission filter is clean, and make sure the fluid level is where it needs to be. If you have a scan tool, you can do a transmission relearn which can't hurt. It seemed to help on my F150. When you disconnect the battery it might not reset everything.
Good luck.
Having operated a fleet of F150's with this transmission, my experience says the opposite. In particular Valvoline fluid causes problems. Replacement with Mercon solves the probs.
Suresh, I bet you understand the difference between licensed fluids vs “recommended.” Are there any “licensed” LV fluids easily available to you? Castrol, Pennzoil, and even Walmart’s Supertech (from Warren) had “licensed” Mercon LV fluids at some point available in U.S. Supposedly, the latest Castrol in US is recommended, but no longer licensed, so be careful. I hope @Cujet sees this and comments. Amsoil ATF has a good reputation, but doubt it’s any cheaper…but could be better. Allegedly HPL uses even better additives, per a well-respected poster ( molekule?) here, but this is going further down the path that may have led to your issues…though possibly a better detour than LiquiMoly…possibly. All this said, it sounds like you are OK with $13/qt for the real stuff, I just don’t know world market differences.
I was just trying to help you best utilize the 10 qts of true Mercon LV I believe you said you already had. As @tcp71 said, you can probably get 4 qts out without another pan drop. 4 qts (no pan drop) + 6 qts (with pan drop) = 10 qts. Doing both would give you a healthy refresh of your tired fluid. But a fluid analysis in advance, might shed some additional light on the condition of your current fluid. I’m not jealous you are having problems, but I am jealous you can drop the pan without a total front suspension removal as officially required on the U.S. Transit (though there is an alternative approach now being floated to raise the transmission and engine ~2” from the mounts to barely allow pan drop). I hope to do that at 100k to replace filter, clean magnets, and get a drain plug…to facilitate more-routine future drain & fills. Good luck!!!
I need some for the transmissionfer case as well right :)
I was thinking drain with a cold engine and pan drop, let it drip out overnight so there isn't too much circulating inside the transmissionmission.
I've used Valvoline MaxLife ATF is dozens of transmissions over the decades and have experienced no issues of concern. In the 2014 F150 I used a generic brand Multi-ATF from Canadian Tire (Motomaster, made by Shell I think?) and did five drain & fills after pulling the pan and cleaning the magnets.
The brand of fluid used is not an issue, just as with engine oil. I would never consider using Ford brand engine oil / ATF, at double the price, when I can get a superior product instead. Valvoline, Castro, Mobil, Pennzoil, etc have all stood the test of time and no class action lawsuits that I can see. Wish I could say the same for Ford, GM, Nissan, Toyota, etc.
I'm with you for all fluids except the transmission oil. That Liqui Moly fill was a mistake.
There are very few transmissions on the market that are so special that a commonly available fluid on the market won't surpass the performance of the OEM fluid. So many people think their transmission (or other component) is "special" because the mfg has stated as such but this very rarely turns out to be true. We hear it all the time, every year, for decades now.
I've never used Liqui Moly products but I'm sure if they have an appropriate fluid for your application then it would work well. I know from decades of experience (and the visible lack of published articles / lawsuits / etc) that fluids from reliable brands perform as advertised. Red Line, Amsoil, Valvoline, Mobil and even the off/store brands (OEM, MotoMaster) have never disappointed. I HAVE seen several issues that were misdiagnosed / misunderstood and were blamed on fluid BRAND and not on the fluid condition / maintenance history / electrical issue / unknown TSB.
In my most recent case, our warranty replaced CVT transmission was being actively destroyed by the firmware in the TCU that was to be updated at the time of replacement, but was not. I was able to figure this out myself, after a few years, but no amount of maintenance, service or fluid swapping was going to correct the failures of Nissan the Nissan dealer. I contacted ~ 10 dealers in my area and NONE of them were able to explain this to me or to suggest a course of action other than to order a new CVT replacement.
TLDR, high performance transmission fluids are readily available, your transmission does not require a special fluid and supporting your OEM dealer is probably a bad idea.
