Massey Ferguson 6475 (Perkins 1106c)
Out: Delo 400 SDE (CK-4/SN), OEM filters: 1447048M2. Oil was ran from 2,861.8 hrs to 3,079.0 hrs (217.2 hours in service), from 5-17-2019 to 8-16-2020.
In: 15.2 quarts of Mobil Delvac 1300 Super 15w40 and (2) Carquest 85806 filters, made by Baldwin. The filters are mounted base down, so they have a built in standpipe. I believe the Massey/agco OEM filters are a relabeled Wix 51806.
I also replaced the mechanical lift pump with a Delphi HFP068 (Carquest, lifetime warranty). The mechanical lift pump was replaced last year at the last oil change with an OEM Massey replacement after the 14 year old factory pump diaphragm tore and started leaking. The OEM replacement failed after a year and only about 200 hours of service. The pump that failed after only a year from Massey (4225162M1) was $161.28 from the dealer last year. The Delphi pump was $89.50 through a friend that let me have it at his cost.
John Deere 6215
Out: Delo 400 SDE (CK-4/SN)15w40, RE504836.
Ran from 3,725.8 hrs to 4,144.4 hrs (418.6 hrs in service) from 5-25-2019 to 8-17-2020
In: 16.8 quarts of Mobil Delvac 1300 Super 15w40, RE504836.
Changed both fuel filters:
Front: RE509031 (final filter)
Rear: RE509208 (water separator/ pre-filter)
Changed front axle oil:
Out: Hy-gard
In: 6.9 quarts of Chevron 1000 THF
Changed MFWD final drives:
Out: Gear oil
In: 0.6 quarts per final drive, Starfire GL-5 85w140
