Post your latest tractor oil change.
1989 Bolens/Iseki 1502 with Mitsubishi K3A diesel
Out - Shell Rotella T5 10w30 with Napa Gold 1064 filter
In - Valvoline Premium Blue 10w30 with Napa Gold 1064 filter
2006 Nh Tc30. Out Rotella T5 10w30 with bosch distance plus filter. In....see pic
2001 MF 1250 Out Delo synblend 10w30 and Toyota filter. In ...see pic
Kubota G5200 III. Delvac 15w40 and a Fram PH3593a. No idea on hours of the machine or oil since it originally came with no hour meter/ temp gauge.
I've since added a gauge as well as the wiring and a sensor since it'll be used for mowing in the hot summer. Just plug and play.
Your tractor has a bogus oil fill location too. Nice. I ended up using a DEF funnel from AAP. It's light blue. Has a square and angled end since the fill hole is at such an odd angle as well. It's just a pain because the flow hole is such a small diameter as it wasn't intended for oil, but it was mess free.
Yeah I imagine if the hood on the Massey was designed to open on top the fill would be on the valve cover like the New Holland.
or if they would put more of a spout/neck on the oil fill that held the funnel It would be better I had to actually hold the funnel in place upright while pouring the oil in and hold it until it was done draining out of the funnel. what the heck.
Kubota bx1850 only had 20 hours since last changed Delvac15-40 and a super tech filter. It's a pain to change oil. Mower deck and a brittle plastic engine cover has to come off to get to fuel filters, hydraulic filter and oil filter. Have found a way to repair any cracks in the plastic body parts. Using E6000 industrial adhesive and metal window screen. Clean area with sandpaper then degreaser, heavy coating of adhesive, push screen down into adhesive let dry 24 hours, recoat with adhesive let dry 24 hours.
Craftsman 17 HP tractor / lawn mower
Out: I have no idea
We bought it used.
In: Royal Purple's HMX 5w30
2004 JD 6415 MFWD (2,715.6 engine hours)
Out: JD plus 50-II (15w40) and a JD RE504836 filter (467.7 engine hours on both, in service from 2/5/19 to 5/8/20).
In: 16.8 quarts of Mobil Delvac 1300 15w40, JD RE504836 filter
Also changed both final drives with GL-5 85w140 (~24 oz each). Changed front axle oil with Chevron 1000 THF (calls for Hy-Gard -~6 quarts). Changed both fuel filters, JD part #'s RE506031 and RE508208. Changed both hydraulic filters (AL221066, AL203061). Changed outer air filter, AL172780.
International 484
Out: Chevron Delo 400 SDE 15W40
Wix 51768 oil
Wix 33358 fuel
Wix 33472 f/s
In: 2 gallon Chevron Delo 400 SDE 15W40 (Walmart)
Wix 51768 oil (Rock Auto)
Wix 33358 fuel (Rock Auto)
Wix 33472 f/s (Rock Auto)
Greased tractor with a tube of Kendall Super Blu 427
Tractor only gets run 25 to 30 hours a year. I typically always do a yearly service the weekend before Memorial Day. I always mow down my field Memorial Day and Labor Day weekends.
2016 Ford Escape S
Out Havoline 5w20 High Mileage Blend, Motorcraft Filter.
In Pennzoil Platnium High Mileage 5w30, Wix Filter.
5.7 quarts on the nose.
Originally Posted by JustinH
2016 Ford Escape S
This is the tractor sub forum. Lol
2001 Kubota BX2200 with 1,100 hours. Changed Mobil Delvac 1300 Super 15W40 with more of the same. Kept the WIX WL10079 filter. The service interval is 100 hours for oil, 200 for oil filter.
Massey Ferguson 6475 (Perkins 1106c)
Out: Delo 400 SDE (CK-4/SN), OEM filters: 1447048M2. Oil was ran from 2,861.8 hrs to 3,079.0 hrs (217.2 hours in service), from 5-17-2019 to 8-16-2020.
In: 15.2 quarts of Mobil Delvac 1300 Super 15w40 and (2) Carquest 85806 filters, made by Baldwin. The filters are mounted base down, so they have a built in standpipe. I believe the Massey/agco OEM filters are a relabeled Wix 51806.
I also replaced the mechanical lift pump with a Delphi HFP068 (Carquest, lifetime warranty). The mechanical lift pump was replaced last year at the last oil change with an OEM Massey replacement after the 14 year old factory pump diaphragm tore and started leaking. The OEM replacement failed after a year and only about 200 hours of service. The pump that failed after only a year from Massey (4225162M1) was $161.28 from the dealer last year. The Delphi pump was $89.50 through a friend that let me have it at his cost.
John Deere 6215
Out: Delo 400 SDE (CK-4/SN)15w40, RE504836.
Ran from 3,725.8 hrs to 4,144.4 hrs (418.6 hrs in service) from 5-25-2019 to 8-17-2020
In: 16.8 quarts of Mobil Delvac 1300 Super 15w40, RE504836.
Changed both fuel filters:
Front: RE509031 (final filter)
Rear: RE509208 (water separator/ pre-filter)
Changed front axle oil:
Out: Hy-gard
In: 6.9 quarts of Chevron 1000 THF
Changed MFWD final drives:
Out: Gear oil
In: 0.6 quarts per final drive, Starfire GL-5 85w140
