- Joined
- Oct 6, 2020
- Messages
- 2,417
Out: ST FS 10w-30Same mower.
Out: ST FS 10w-30
In: Same
In: Same
Out: ST FS 10w-30
In: Same
Interesting technique. I usually just jack it and pull the right front wheel. I may have to give that a try.Used an Ocean Spray cranberry juice container , helps w/ less mess . Usually use empty 2 Ltr. bottle of soda , gave up drinking diet sodas .
Place ramp under each tire on right side of mower for engine oil draining pipe w/cap and then ramp beneath both left side tires for oil filter to give a better extraction and less mess of oil change .
Oops, the ramps should be the opposite of what I stated. Place ramps under tires of opposite side to be drained of oil .J.D. D130 w/ B&S 22 H.P. twin :
Out : Mix of oil weight and brands making synthetic 5w-30 w/ J.D. AM125424c oil filter
Post#1279 : https://bobistheoilguy.com/forums/threads/post-your-latest-small-engine-oil-change.128191/page-64 .
In : SHELL Rotella G.T. 5w-30 ( S.N.+ , GF-5 ) w/ same oil filter .
View attachment 75786View attachment 75787View attachment 75788View attachment 75789View attachment 75790
This mower would be a great addition to the photo thread! Gotta love the custom projects!Changed the oil on my frankenmower. It’s a 90s Lawnboy steel deck with a 90s Honda GCV160. The Honda was saved from yard trash and swapped onto the deck, which was given to me by my neighbour when the engine blew. The engine had sat for a long time but ran great after a deep carb clean. I changed the oil at the time of the swap a couple of years ago and decided to do so again this past weekend. It definitely needs to be done at a higher frequency (at least until it cleans up the engine a bit) as it came out very dark.
Out: QSAD 10w30
In: QSAD 10w30
