Post your latest small engine oil change
Deere Z375R 137.1 HR
Out 2.5 Q Chevron Delo XSP 5W30 Wix 57035
In 2.5 Q Chevron Delo XSP 5W30 Wix 51348
Sta-Bil Storage added to the gas
2019 Ariens Snowblower with Ariens Chinese clone engine
Out: factory fill
In: Pennzoil Conventional 5w30
No leaks but auger gearbox seemed a bit low, topped it off for customer.
Honda GCV160 lawnmower
Out: 10w30 + drip oil mix
In: 10w30 + drip oil mix
I let the oil drip out of the bottles from all my other vehicle oil changes. This go into the mower and topped up with 10w30. I usually get a few ounces of oil out of the bottles each year.
2002 Craftsman 22" Multi-Cut lawnmower with 650 series Briggs & Stratton engine.
Out: Briggs & Stratton SAE 30
In: ACE 4-cycle lawnmower SAE 30, with a splash of MMO.
Changed air filter as well.
2015 John Deere D140 lawn tractor. 215 hours on the machine and 40 hours on the oil and filter.
In and Out: 15w40 RT6
A Fram TG3614 filter was left in place for a second season. That's a 15,000 mile filter in automobile applications and 40 hours on the Deere would be 1400 miles in a typical car. I figure you could handicap this by 5X for severe service / air cooled OPE and would still be okay for 100 hours.
2021 Simplicity Courier 42 inch Zero Turn
Out: Factory fill
In: Amsoil Small Engine 10w30, Briggs & Stratton filter# 696854
2000 Craftsman 22in some type of briggs Quantum engine.
Out:???
In: Rotella T4 15W40
Gotta get a brake cable for it, the previous owner had the brake cable snap, they bypassed the brake but the kill switch was still staying activated, I pulled the wire for it and have to push it up against the spark plug to ground out the coil to kill it, so before I can truly use it I need to fi that because that's just not safe.
I use any DEXOS 1 / Gen 2 5W30 synthetic oil and change it out before putting mower (Honda 190) away for the Winter .
Honda 216 Lawn Mower. Out Mobil 1 Extended Performance 10w30 : in 11 ounces Castrol Edge 10w30 (only thing on Walmart shelf). Best to change the oil after last mow every Fall.
