- Joined
- Dec 20, 2024
- Messages
- 1,739
Also, if you dunk Mobil 1's brochure in sulfuric acid - it dissolves.The Mobil 1 jug is easier to carry because the handle is mounted higher. Advantage Mobil 1. The Valvoline jug is easier to pour because the handle is mounted lower. Advantage Valvoline. Colors are essentially the same. Tie.
Yet, if you dunk Valvoline's brochure in spring water - it just gets wet.
Obvious and overwhelming advantage: Valvoline.
