Post your latest oil or filter purchase
Fuel additive 😷
Oil and filters for upcoming oil changes and then dad got a couple quarts of oil at Big Lots to for his car because it uses a quart about every 2,000 miles or so which isn’t too bad. They had SuperS oil brand for $2.00. There is clearance signs up for about everything in the store which is nice. I am glad to have Big Lots back. I told the parts guy at work to surprise me with oil and get the usual filters so he got Castrol and Mobil 1 good choices in my opinion.
View attachment 303609View attachment 303610
Nice
I haven't seen Super S since the last Kmart in the area closed about 5 years ago
2 OEM filters for either my son's Forte or his wife's Tucson. An OEM element for my daughters boyfriend and his '21 Sonata 2.5L. Went by AAP to get a Carquest also. Factory has a new screw in plug for the oil filter housing, I wasn't sure if the CQP did (it does also). The difference is the factory one has a larger diameter on outside and covers some of the 27mm "nut". If you leave it out after drain it keeps dripping some into your tools. I swapped the new O-ring onto the plug that was in there. It recesses nicely into the housing. The CQP also has that smaller outside diameter.
Side note thinking of @Glenda W. - while waiting for parts guy at Hyundai dealer, observing a very nice looking technician, maybe in her early-mid 30's, engine on a hoist, impacting parts off of it. Thinking that's awesome as I don't normally see many women in the shops I go to. No clue for what vehicle and why as it was blocked by another vehicle.
Dealership oil out (unknown). In goes OE Honda 0w20 Ultimate Synthetic + 1 bottle of Idemitsu ZEPRO Eco Medalist 0w20 I had on hand, 4.2 qts.
Based on the cap design and the font used for the measurements on the sight glass, these oils appear to be made by the same company, or at least the bottles are made in the same factory, IMHO.
View attachment 304417View attachment 304459
That’s a P66 bottle …
I don't even own a boat but I bought 3 gallons of 2 stroke boat oil for 9 a pop so I couldn't resist.
Went to Walmart for cat food and other things and told myself that I would not be buying any more oil cause I had enough but I had 4 stroke oil in mind so this didn't break my rule. I'll use it all up. I run it in every gas tank I get my hands on.
I know you mentioned OPE - using in vehicle gasoline as well?
Cool - just started on the Jeep (3rd tank @ ounce/5) - I needed to quiet down the injectors so I can catch a valve train failure early on 😷
640:1 is light. 1oz per 4 gal is 512:1 and 1oz per 3gal is 384:1 which is what I run but with what's left over in the tank that's already treated and with the slight change in how much I refill it's impossible to get a perfect ratio every time but it's approximately 400:1. That usually bounces from 380 to 410 or so. Try 1oz per 3 gal.
Yes indeed, came across my Wal Mart feed so jumped all over it. Now I’m going to have to chew the folks out at ALS as they say my FRAM 10w-40 sample is lost somewhere there. 🤬🤬
Told them ā€œthis is not happening and it’s un-acceptable!ā€
I'd demand that they send two new sample kits back if they don't find it.
