Post your latest oil change
2024 Jeep Grand Cherokee 3.6L pentastar 3600miles
in service 3600 miles
out/off: 5 quarts factory full + factory oil filter
in/on: 5 quarts Pennzoil Ultra Platium 5w20 + Fram Titanium FS11665
co-worker’s wife’s new ride. i told him to change at 1500 miles then every 5k after that. he didn’t listen. i set the OCI sticker for 5k miles. whoever designs for Stelanis needs to be fired. two different sized fasteners to let down a trap door to get to the drain plug then having to remove the intake piping to get the oil filter out. i will never own anything engineered by ford or stelanis lol. 3600 miles and ticking like a time bomb.
2017 Ram 1500 Crew Cab 4x4, 5.7L
Out / off: Valvoline Advanced syn 5w-20, Fram XG10060
In / on: Valvoline R & P syn 5w-20, Fram XG10060
This truck gets oil changed annually or 5000ish miles, whichever happens first. OLM at this change was at 45% remaining (reset). I may run the OLM down to 10% on this OCI and have an oil analysis done (sometime next year).
2018 Subaru Legacy Sport. 59,422 on car.
6,072 on Oil and Filter
Out/In: Mobil 1 Extended Performance (Both non triple action formula. Got 2 more jugs of that before I get to the triple action.)
Off/On: Wix 57055
Will put in the Redline SI-1 when I fill the tank. Attached are pics of the fill hole. Couldn't get anything better. For the first two years car had oil changes probably ever 2500 miles. Since my wife has been driving it a few days a week it has been a steady 6k/6m oil change with Mobil 1 Extended Performance except one HPL change. "Should" be pretty clean.
2003 Toyota Corolla, 220,054 mi., 5k OCI
Out: Quaker State Synthetic 5w40, Parts Master 61348 filter (Camry V6 oversize)
In: 3 qts. Mobil 1 5w30 HM, 1.25 qts. Mobil 1 5w30, Parts Master 61348 filterView attachment 227287
@ChrisMU how much extra oil is needed to account for the larger filter? I am considering the larger filter for my Matrix at some point, and will need to account for the filter (and the extra .5 qt per T-SB-0134-08).
2017 Outback 65k 3500 OCI wanted to put Castrol EDGE Extended Performance back but only can find it on Amazon it’s $37 is for 5 quarts right now. Maybe next time it will be back under $30.
Out
5w30 Castrol EDGE Extended Performance
Subaru Tokyo Roki filter
In
Mobil 1 Extended Performance 5w30
Blue Subaru USA made filter
When I used the standard Corolla filter, I put exactly 4 quarts in. With 4.25 qts I put in this time, the oil level after two days of use is 2 mm above the full dot on the dipstick. I have also used the larger common Ford FL-400s/3600/51516 filter in the past, along with about 4.5 quarts, and had no issues. Then I got a good bulk deal on some Camry V6 size spin-ons.
What were the Oil Life monitors at for each
car? 20 months sounds like European drain intervals. Thanks.
Yeah this was definitely longer than what I typically feel comfortable with! However, I figured with the Mobil 1 0w-40 being well rated for long intervals it should be ok if we don't make a habit of it. These vehicles usually get up to temp for a while when driven, so I'm more focused on the miles.
I didn't reset the OLM on the BMW at the previous change, so at this change it was at -125 miles for two OCI.
The Smart uses days, which was -572!
Mom's 2004 Honda Element
171,291 miles
Out:
5qt some ungodly concoction (during OCI I've added 2+ quarts of oil as the pan gasket leaks and it also burns oil)
STP ST6607 filter
In:
5qt Thrive synthetic blend 5w30
Kawasaki 16097-0012 filter (no idea why I had one of these but it cross-referenced and worked!)
