Post your latest oil change
2014 Scion XB
63,200. OCI 4200 mi.
Out: Castrol MT 5W30
In: Castrol Edge 5W20
Wix filter out, Denso in.
PCV valve changed for 2nd time. Wiper blades.
2013 Scion XD
62,400. OCI 3200 mi.
Out: Valv. Adv. 0W20
In: Valv. Adv. 0W20
Got lazy and left filter ride until next change in Spring. Wiper blades.
2004/2005 Yardman 8 hp snowblower.
Out: Honda power equipment 10w30
In: Super Tech syn. ATV 10w30 API SL
No air nor oil filters.
Changed my fiance's oil.
2012 Honda Fit 1.5
Out: Mobil 1 High Mileage 0w20/15400-PLM-A02
In: Valvoline FSHM 0W20/TG7317
It had a slight lifter tick and when I drained it the oil was like water. Tick went away after the change so I wonder if the Mobil 1 couldn't handle 6 months in her car. The Valvoline modern engine I've used the past few years never came out like that and I changed it yearly with it so we'll see if the Valvoline high mileage comes out like water or not.
2022 Hyundai Ioniq hybrid
Second of early changes. 1047 on odo
Out: Pennzoil Platinum 0w20/OEM
In: Castrol EDGE 10w30/OEM
Allowable per Owner's Manual:
0/5w20, 0/5w30 and 10w30
That access looks very convenient. Love it when companies think about maintenance.
It is. I posted it because i know some new Hyundai vehicles use a cartridge filter that requires a step or two more to remove. Like you said, i'm glad its straight forward and very easy.
For those questioning the drop of oil on the filter, i had already loosened it to allow partial drain before removing it. Less mess that way.
2008 Acura TL in Signature (127,343)
Out -- 4.25 quarts of Pennzoil Ultra Platinum Plus 5W20 (5,073 OCI)
In -- 4.25 quarts of Rotella Gas Truck 0W20 & 2nd run on Fram Ultra
Was 71 degrees here today in Berks County Pa... They are calling for the highs in the low 40s tomorrow soo I jumped on it right after work.
It was 69 here outside the Burgh’ yesterday and today like 44. Crazy PA weather. Heading to Carlisle area Saturday early morning
2019 RAM 1500 Sport, 5.7L HEMI
- Out: Mobil 1 Extended Performance 0w20, FRAM Ultra XG2
- In: Mobil 1 Extended Performance 0w20, FRAM Ultra XG2 (OG)
Mileage: 49,044Km
OCI length: 11,716Km
Also performed:
- Brake service
- F/R diff fluid change (Mopar 75w-140 rear, 75w-85 front)
- T-case fluid change (Mopar fluid)
Work performed at dealership w/supplied oil and filter per free lifetime changes
Just got the oil changed in both the Buick and the Honda. Used up the last of the Mobil 1 Extended Performance 0w20 for the CRV and still working through my stash of Castrol GTX HM for the LeSabre. The CRV went 6000 miles and was black with the expected smell of gasoline. Took some pics of the oil out of the Buick. Only 2k over the last year and no gas smell but a year is the longest I wanted to go with either vehicle in part because getting the filters off is always a bit stiffer than when I normally do my OCI's @ 6 mos. Carquest Premium filter on the CRV and the last of my K&N Gold filters for the Buick. Have another Carquest Blue left for it but will likely go back to Wix for both after I'm out. Funny how selecting oil for the Honda requires a bit more of my brain cells, but for that 3.8 in the Buick, well, it just isn't picky as long as I keep the viscosity on the thicker side. I have run Castrol Edge HM 5w30 before and it was fine but other 5w30's sometimes create clacking noises when starting in cold temps so 10w30 it is. I do have a oil pan warmer if need be. Will see how Winter rolls this year in the Great White North!
I'll be doing another OCI by Thanksgiving on the Altima in my sig. Most likely I'll use either CarQuest Full Synthetic or SuperTech Full Synthetic. I have both in my stash. And I may in fact keep on the same ULTRA filter as it only has ~10K miles on it so, one more OCI isn't going to hurt.
2015 Honda Civic 1.8 LX(TOTALED) I just hate it when that happens.
