Post your latest oil change
changed my 4runner tonight. 417k miles
out : pentosin 5w30 with wix filter
in : mixture of pennzoil 0w30, an quart of m1 AP 5w30, an quart of m1 5w30 and half quart of Valoline modern engine synthetic 5w30. ran out of oil so took mixture of what I have left and a little cocktail lol
around 4k interval.
runner is little quiet than before
Changed both motor and gear oil last week.
2017 Golf GTI Performance in my signature (52,000 km, no known issues)
out: Ravenol VMP 5W-30 (VW 504 00)
in: 5.7 l Ravenol REP 5W-30
filter: OE VW 06L 115 562 B (Mann HU6013z)
drain plug: custom made magnetic
out: Castrol Syntrans V-FE 75W-80 GL-4
in: 2.0 l OE VW G 052 527 (which is a 70W-75 or 75W GL-4) + 0.5 l Castrol Syntrans V-FE 75W-80
Motor oil had about 6000 km and one year, gear oil about 42,000 km and four years.
2018 Mazda CX-5 39,839km
OCI/FCI: 9,158km 1 year
Out: Pennzoil Platinum 0w20, Fram PH6607
In: Pennzoil Platinum 0w20, Fram XG6607
The oil comes out like water on this thing. I change three other cars (‘13 CRV, ‘13 Mazda5, ‘12 xD) that use the same oil and none have the oil pour as fast or look as thin. Is it the DI?
2015 Cadillac SRX
3,720 miles on the OCI - OLM was down to 15%
Out: Mobil Super Synthetic 10W30
In: 50/50 Mix of: Mobil Super Syn 5W20 & Valvoline 0W40
- Didn't change the Wix XP oil filter
2018 VW Golf Sportwagen. Modified for >2x orginal power. Just did 2 track days so early change. 69,466 miles, 3,916 miles on OCI. No oil consumption.
Out: 6 qts Liquimoly Molygen 5W40 + Liquimoly MoS2 + used Liquimoly Engine Flush prior to change, Mann filter/o-ring/drain plug
In: 6qts Liquimoly Molygen 5W40, Mann filter/o-ring/drain plug
FCP Euro - used oil going back for a full refund + shipping refund from PayPal.
2013 Chevy Equinox My Moms vehicle
This vehicle has already had the timing chain replaced and the oil consumption issue dealt with at the dealership.
She brought it over because the check engine light was on. The code showed the secondary air injection pump was stuck. Ran seafoam top motor through the intake and poured seafoam in the crank. This cleared the code right up.
Mileage147,197
Out and Off what ever Goodyear uses. I believe Castrol. 5,000 miles on oil and filter
In 5qts of Valvoline Maxlife FS 5w30
on Purolator Boss PBL15436
Also changed the air filter with a Fram Drive FDA10465
Topped off coolant.
Set tire pressure correctly
