Post your latest oil change
Today...
2004 Chevy Tahoe Z71
168k
out: Valvoline Maxlife 5w30
in: Napa 10w30 Synthetic, ATP AT-205 reseal (hopeful it will slow a RMS leak)
AcDelco pf 46e
If you have access to a lift and good tools, those aren't terrible to do a rear main seal in.
Phillips Xc20w-50, 11 qts., Tempest filter, annual service. Nice break from the office!
I have had good success with 205 Reseal. And it does not harm to anything else, we will see. Leak ait that bad.
I don't know about that it's glycol ether which is essential DOT3 brake fluid, so I'd watch using it as it can possibly damage any rubber seals it comes in contact with, and GM has had a tendency to use Teflon rear main seals so seal Swellers may not help at all
I had a slight leak on my 1999 7.4 suburban 140k+ a while back, used it and dry as a bone now so we will see.
2010 Nissan Frontier 6 cylinder 4L
87397km (54305 miles)
6443km on oil (4003 miles). 7 months on oil
Out: Pennzoil 5w40 Euro and Fram Orange can
In: Quaker State Euro 5w40. No filter change. OEM crush washer.
The new filter is in the picture but I left the old one on instead. I’d like to do longer OCI but seem to have trouble doing it.
Jeep Grand Cherokee WK2, with ecodiesel.
330 000km service done. Petro Canada Duron UHP 5W-40 Motor oil together with BG EPR cleaner, Fram tough guard filter. New Fuel filters, Air filter, cabin filter. Also transmission filter changed with Petro Canada Duradrive MV fluid.
Perfect!
2022 Toyota Tacoma truck with 2.7 4 cylinder engine. Friends truck. 10k on vehicle.
Out: Toyota factory filter and some Quaker State Ultimate Durability 0w20. I helped him do last oil change. He said “let’s leave the DENSO filter on til 10k” so we did.
In: Quaker State Ultimate Protection 0w20 and FRAM ENDURANCE 3614 he brought over.
2012 Toyota Corolla Supertech 0w20 synthetic, supertech filter. Car gets driven less than 7,000 miles a year so I'm going to try and do a one year oil change. It's not really an "extended drain" since Toyota recommended 1 year or 10,000 miles on synthetic oil. An engine without direct injection or a turbo, we'll see I'll probably get the oil change shakes after 6 months.
Perfect!
Where do you buy Petro Canada fluids? I’m assuming not at the gas station, as that seems crazy expensive.
