Post your latest oil change
Helped my little brother change the oil in his 18’ Corolla
Oil change mileage - 182629
Oil change date - 6/3/23
Motor oil used - Mobil 1 0w-20 AFE
Oil Filter Used - Wix 51945
Miles on oil - 5801
Oil out - blend of Mobil 1 0w-20 AFE, Castrol Edge EP 0w-20, Pennzoil Platinum 0w-20
Oil in - Mobil 1 AFE 0w-20
Craftsman Garden Tractor GS6500 Kohler 26HP
Hours on Filter/Type: 150 hrs/ FRAM PH7575
Hours on Oil: 5
Oil Out: 5W-30 Synthetic (for winter use, plowing snow, but not much snow this past winter. Still decently golden, just slightly tinted)
Oil In: 10W-40 Pennzoil Conventional HM (for summer)
New Filter: FRAM PH7575 (last of the clearance filters purchased at Tractor Supply for $0.49)
Probably could have gone longer on the filter, but wanted to check it. Filter was quite clean overall. One side of the filter element was dirtier than the other, probably a function of how the oil flows into filter or its position. Nitrile ADBV still nice and flexi, along with the gasket.
Girlfriends new to her 09’ Focus base edition. 189k and manual trans.
Out: unknown oil and Mexico made “Tec Select filter.
In: I’ve been called nuts, stupid, amongst other things but delo of any grade at clearance price of $7 a gallon at Wal Mart: priceless. Got last 9 jugs on shelf too💀👽☠️😜😜
2007 Toyota FJ Cruiser w/4.0L 1GR-FE w/226,500 miles
Doing a custom blend this time around. 4 1/2 qts of Mobil Delvac 1 ESP 5w30 and 2 qts of Valvoline PB "RESTORE".
Installed new Fram Titanium FS8A in the full flow position and a Amsoil EaBP90 on the remote bypass filter mount.
Sent a sample to a OAI/Polaris lab to get a baseline. Took the sample after driving the vehicle around with the custom blend for 30 mins.
My dad's/mine 2008 Chrysler T&C touring 3.8 V6 80,000 miles.
Vehicle was only driven a few times the past 2 years and it was started about once a week. Didn't write down the last oil change on it, but it wasn't very many miles in those 2 years until I started driving it here and there recently. The oil had a funky smell to it, smelled like a combo of fuel and condensation.
Out: Milesyn synthetic blend 10W30 Hastings LF115 filter.
In: Mobil 1 European 0W40 and a STP 3614 blue filter.
This engine does well on 10w30 or 10w40 as far as oil consumption is concerned. It drinks 5w30 or 5w20 to the tune of about 1 quart every 700 miles, but about 1400-1600 miles on 10w30 or 10w40. We'll see how it does with the 0W40.
Friend's 2015 Lexus RX350
Odometer: 108,646 miles
OCI: 5,810 miles, 11 months
Out: 6.5 qts Castrol Magnatec 0w-20, Toyota 04152-YZZA1 filter
In: 6.5 qts Duramax 0w-20 synthetic, Fram CH9972 filter
This was my first use from the Duramax six gallon box advertised in 2022 at $1.98 a quart with free shipping (likely a pricing error). Several BITOG members had their orders cancelled. I was a lucky one. Overall my stash is down to 128 quarts.
2017 Tacoma 3.5L V6
Vehicle kilometers - 69455 (43062 miles)
Oil change date - 6/6/23
Oil in - PUP 0w-20
Oil Filter Used - M1-251C
Kilometers on oil - 14820 (9188 miles)
Oil out - PUP 0w-20
Note: Filter plastic drain piece supplied with this newer M1 filter version is not very good, it does not screw in. I saved an old one which does thread in, much better. I cleaned it and will keep using it. End cap o-rings are now absent on these new M1 filters.
2020 Nissan Rogue
Mileage on unit: 50,050
Mileage on oil: ~3600
Out: 5qts Castrol GTX Full Syn 0w-20 & ST 6607 oil filter
In: 5qts Valvoline Daily Protection Semi Syn 5w-30 and ST 6607 oil filter
Bought the car with around 46,400 miles back in March. Immediately changed the oil then even though it looked brand new. Changed it ahead of my normal 5,000 mile OCI so I could round it off at 50k for easy intervals.
