Originally Posted By: toyotaguy
How you like that SSO in the corolla? Ive been thinking about doing that. I put a lot of miles on my car, a lot of hwy.
The motor's a little noisier on it than it was on the ASL. But otherwise, it's okay. No change in mileage either.
97 VW 2.0L I-4:
Eco Power Synth blend, 5w30, 3.5 Quarts, plus half a dose of Mr. Moly MoS2 and half a liter of Pennzoil 15w40.
Originally Posted By: 3putter
Wow, this thread has legs.
2009 Chevy Malibu 2.4 liter Ecotech
5w30 Kendall GT-1 with a Firestone House brand filter.
It looks my like the Firestone over here just depleted their Kendall 5w30 Synth Blend, and has now switched to Safetly Kleen Synth blend.
Just recently I had one car (a soobie) done end October and it got GT-1 (luckily!), but I took the VW to Firestone today and was sad to see it got Eco Power recycled oil from Safety Kleen; yuck. I'm a little worried it'll have sub minimal additives in it, esp ZDDP; I threw in some molyslip for now, just because I was so ticked off.
Here's the link, but it has nothing useful but a little safetly kleen PR bits. http://www.ecopoweroil.com
Why not get a VOA done?
If the oil passed API SM and GF-4, is it even possible for it to have a sub-minimal additive level?
So long as the quality of the Eco Power stuff is satisfactory and consistent, I'd be interested in it; no sense constantly extracting new oil simply to use it once and throw it away. If it can be effectively cleaned and re-refined (considering they refine nasty crude into effective oils, re-refining once-refined oil seems quite easy), that seems like a brilliant idea to me.
It would probably do a lot more to help the environment than a whole ton of Priuses.
Ugh, sub-minimal by my definition... I had just really liked the Kendall stuff as it worked great for me over the past few years, and just now looked at some of the UOA's of Supertech and other safety kleen recycled oil using the forum search. They ranged all over the place but one UOA was not even 500ppm zinc; and the highest was like in the zinc 700ppm range? I dunno, some of these OA posts just didn't look that great for additives elements. They may have improved their additives over time; but I just don't know. Yes it would be interesting for a VOA; I plan to do a UOA in the fall of 2010 to test a new moly supplement.
Re the conservation: If a well over a hundred gallons of fuel is burned for every gallon of motor oil used, will this really make that much of difference you think? Seems like using virgin oil but cutting down on driving or getting a car with 30% better mpg's would still go further for conserving resources. But I guess I don't object to recycled oil if the additives are top notch.
I just did a "Gold Standard" oil change for my moms 2002 Ford Explorer with the 4.0 V6. 5 quarts of Castrol Edge with a PureOne oil filter. I took advantage of Advance Auto Parts' $25 Castrol synthetic oil special.
