2024 Totals: "Post your latest oil change"
...Also in 2025, can we ask users to post whether if it is GF-7? This will determine how many early adopters there are and the number of die-hard users reaching into their stash.
I am pretty sure most BITOG users have an oil stash.
Running a GDI motor, I'm planning on using GF-7 as soon it becomes available at my Kia dealer or at the indie garage that I use for oil changes.
Regarding oil stashes: My last five cars did not use a drop of oil during their tenure, so every now and then a never-opened bottle of old oil turns up in my stash of automotive lubricants. Most recently, a 2011-vintage bottle of GF-5 Mobil 1 5W30 resurfaced...and, somewhere, there's a bottle of Total "Turbo Formula" 20W50, purchased around 1990, back when there were Total gas stations here in Michigan. It's probably next to the bottles of Type F transmission fluid that'll never get used.
Was surprised that the only OEM oils to make the list were AC Delco, Motorcraft, and Toyota. Honda lubricants do get mentioned on here from time to time, but didn't make the cut for whatever reason.
Throughout the year, I bet many Frankenbrews go unreported.
This is not to disparage the findings, just a guess.
Ha-ha,,,think of all the certs Frankenbrews might have!
More like think about how many oils have been ruined by mixing their chemistries with other oils 🤦‍♂️
I get it that sometimes you need to mix to use up old oils but we have a few members here who mix on purpose because they think they know better than the experts who built the oils 🙄 And in the end they are really not achieving anything at all.
I think it’s more about being a cheapo and thinking you have to use up everything. You cannot just recycle that quart of oil you picked up for 30 cents 10 years ago - that would be ridiculous.
Is that a certainty? I've read it here but can't recall the proof or even specific, known clashers.
I'd bet there are plenty of basic oils which would mix without bad results.
I’m not saying that the oils will ruin the engine but if you are expecting the oils to still pass the same approvals then that’s unlikely.
It’s just silly to think that the average person with no experience in the industry can play backyard chemist and actually make an even better oil. It’s not happening
We have no idea how mixing affects the resultant oils performance other than some tests showing very low temperature degradation with the particular oils tested. I can guess, give my opinion and assume. But no one truly knows.
329: Mobil
212: Valvoline
178: Pennzoil
138: Castrol
104: Quaker State
82: HPL
73: Supertech
65: Amsoil
61: Fram
46: Kirkland
46: Napa
43: Frankenblend
41: Havoline/Chevron/Delo
40: Swepco
36: Shell
22: Xtreme Syn.
20: Motorcraft
16: Total Quartz
14: Liqui Moly
13: Safety Kleen
11: Toyota/Lexus
10: Motul
10: Redline
8: AC Delco
8: O'Reilly
7: Nulon
7: STP
6: Schaeffer
5: Royal Purple
5: Rural King/Providence
.......and a whole bunch of other brands that had less than 5 users
These results are pretty accurate, although there might be a slight margin of error.
Have a Happy and Healthy 2025 BITOG Community.
Warren Oil makes a strong showing in 5th place: Super Tech + Kirkland = 119 total.
Around 1982 GM became more heavily involved in 5w30 factory-fills. Leery at first, I started blending it with my 10w30 / 10w40. Then I began blending multiple oil producers brand names. Then into the 1990s and 2000s, my backyard chemistry evolved into experiments using 5w20, 0w20, 10w40, 15w40......etc.
No damaging effects for over 43 years now. My resultant frankenblends performed marvelously and still do to this day. My latest batch was blending HPL Performance Plus 5w30 with HPL No VII 10w30. The board-broadcasted Ester base from one and the board-broadcasted PAO from the other, have gotten along great so far. If there's an Additives Clash going on, I'm not seeing or hearing any evidence.
Life is good under my wife's Kia 2.0 MPI hood using HPL. Keeping the OCIs short since 1970, keeps me and my engines happy. Been doing similar with my Hyundai 2.4. Clean and quiet as a church mouse.... so that engine looks and says.
I’m no tribologist but everything I’ve read about formulating an oil is a balancing act. A little of this improves X but hurts Y. To much of a good thing or not enough is bad. One can not tell what affect mixing oils will do to overall performance.
Valvoline has huge gains with the sale of Valvoline Restore and Protect for sure $$$$$
And on the flip side of that, I think we’ll see a decrease in HPL. Trading one “it” oil for the next.
Mobil will remain on top. I think Castrol and Pennzoil will have both weakened.
I think that you are going to be proven correct on all of the above. What I find interesting is the the oil change and used oil analysis threads seem to tell very different stories. I suspect that people who invest in used oil analysis place more value on an extended drain interval than cleaning.
One reason why I think the oil change thread is actually bogus when it comes to representation here is because we have a small number of members that post in that thread nearly everyday who are clearly servicing vehicles in a shop setting. I wish it was implied that you should only post oil changes you’ve performed on your personal or family and friends’ vehicles, because it surely skews the results.
Not everybody does used oil analysis but that may be an actual better representation here of what’s in BITOGer’s vehicles.
Not based on the used oil analysis data I see...mostly seems to be shorter OCIs. What would be interesting would be calc'ing the average OCI from the oil change and used oil analysis threads.
That would knock Swepco, Safety Kleen, Fram and others off the list I would think.
