I'll see if I can get another video of the o-ring area, once the front cover is off but before the pump is removed. What I have shows only one side. I'll post photos and/or a video clip. The one I have is around 280Mb, so I need to edit it down.
This could simply be a case of a less careful oil pan installation. I'm also a big fan of engineering things so less care is anticipated
If I get to rebuild the engine, I'm going with a separate oil pickup tube, that bolts into the pump.
I'm out and driving it this afternoon to experience the rest of the Jeep. Once the oil temperature is at (precisely - it's kind of like flipping a switch, hmm..) 185 degrees, the idle pressure is enough to quiet the lifters, and it rapidly ramps up to 30-45psi when driven/fast idled.
