Originally Posted By: cptbarkey
Originally Posted By: Vikas
A professional mechanic can develop a calibrated hand with experience. Most of them do not use torque wrench for routine jobs.
show me factual numbers where ignoring torque spec's is a good thing then i might believe you.
Obviously, one needs to torque fasteners correctly. However, as an experienced tech, sometimes the drag torque varies wildly. It seems silly to measure the drag torque on each fastener that holds on a plastic belly tray-drip pan. Experience shows that simply ensuring the fasteners are tight, by hand, is sufficient.
I could, for example, set the required torque on the driver, and 1/2 the fasteners would bind, half way in. The plastic belly pan, would then be improperly installed. Or, I could run the fastener in, by hand, when it gets tight, measure the drag torque, add it to the required torque and try again. Only to have it bind some more as it's going in. (this seems silly for such a non critical item, subject to corrosion, poor manufacturing tolerances and so on, no? )
Or, I can simply tighten it, by feel, until it's properly seated.
Doing so carefully will ensure a lifetime of use, without problems.
