My Ford/Lincoln Front Differential Leak Experience
NYC
This thread is in regards to the Ford Expedition, Ford F150, Ford F150 Raptor and Lincoln Navigator front differential problems in the 2021 through 2025 model year vehicles. Im posting this here because I want to be helpful to whoever finds it. There are a bunch of different threads on Reddit and in F150 forums about it.
My former vehicle was a 2023 Lincoln Navigator L and it developed a whirring noise which turned into a grinding noise. Every time I took it to the Ford dealership I kept getting the run around. One day I took it to an independent mechanic who was extremely helpful and way better than the technicians at the Ford dealership. He showed me the front differential. Fluid was black (out of a new bottle its clear) and there was a glittery silver metal running through it. He told me the front differential was literally eating itself. I took photos and went back to the Ford dealership. The next thing I knew they had my truck for over a month. When I got the truck back there was that noise again. Took the truck back to the dealership and they replaced the left wheel bearing...still there was that noise...took it back and they replaced the the right wheel bearing...still there was that noise. This eventually ended one day when I sold the vehicle to Carvana and got myself a 2025.
I thought all the problems of the 2023 "Covid trucks" were solved in 2025...little did I know that I was wrong. All of a sudden I heard that whirring noise. This time I took it to an independent mechanic to have a look. He told me the front differential was leaking and showed me the entire bottom was wet with gear oil. Furthermore he ended up adding gear oil stating there was only 1 quart of gear oil left in it. After that I drove it around and looked underneath. Sure enough there was a drip. I took it to the Ford dealership and after 1 hour their best technician took me aside, looked me in the eye and told me it was the fill plug...he told me there was not enough sealant on it. The gear oil was passing through the threads.
So I left the Ford dealership and take note I will never go to that one again. Either they were deliberately lying to me or they did not know what they were doing. I went right back to the independent mechanic and decided to take matters into my own hands. I spoke with the independent mechanic and asked if he knew where it was leaking and what he needed to do to fix it. Affirmative! He told me what he needed and that was "Permatex Grey". I enjoy being informed about these matters so I turned to the internet for a crash course on sealant. There is Permatex Ultra Grey and Permatex Optimum Grey. The Optimum Grey is an improved version of the Ultra Grey. I went around to 3 parts stores and finally found a single tube on the shelf of the Optimum Grey. Apparently Optimum Grey is a very popular product around here.
The "fix" the mechanic told me was to take off the metal cover on the differential...there are several bolts...and seal it with the Permatex. He pointed out there is no gasket between the cover and the differential. I looked on the Ford parts website and he was right. Somehow Ford thought it was a good idea to have no seal between the cover and the differential. (see attached image).
Yesterday the entire truck was left at the mechanic at 8am. On the Reddit and Permatex website there were certain ways to use these sealants to perfection. After use you really should not disturb it for at least 6 hours, but preferably 24 to 48 hours. After the work was done I opted to pickup the truck 15 minutes before the mechanic closed for the day allowing it to sit for at least 6 hours. I drove the truck right back to home which wasnt far and its been sitting in my driveway. Im going to try to leave it alone in the driveway until it reaches at least 24 hours from the time of installation. In various forums it was suggested to leave it sit overnight. One forum even stated to try not to disturb it for 48 hours.
As for the gear oil to use, prior to 2015 was 80w90 in the front and 75w140 in the rear. After 2015 because of government CAFE mpg (fuel economy) requirements its been 75w85 in both front and rear. I went with Amsoil 75w140 in both front and rear differentials. Amsoil is well known for putting out premium oil products and since these differentials only hold 2-3 quarts I figured it was a good idea to get the best. There wasnt much of a price difference between the Valvoline gear oil on the Walmart shelf and the mail-order Amsoil. To sum up you absolutely should not put the 75w85 into the differential. If you really want it to last you should go thick and get a premium gear oil. Ive read about different change intervals on the internet. Conventional internet wisdom states to change it at least every 50,000 miles, but some state 30,000 miles. There is a tendency for water or condensation to get into these things and for offroad or oil field work thats something to think about. Take note some members of this forum advised me to go a little thinner on the front differential and that advice was noted, but I decided to go the thicker route. The differential was leaking...had problems with the front differential in the past...lets go thick and dont look back.
To sum up if you are hearing a whirring noise up front and to the left on a Ford or Lincoln truck / suv than carefully examine the front differential for leaks. Its not hard to crawl underneath the front and take a look yourself. Start at that point. Most likely it will be a slow drip drip leak and over the course of lets say 15000 miles about half of the gear oil is left. It takes about 2.5 quarts. You probably wont see it on the pavement or driveway. It will drip out during operation of the vehicle.
Many manufacturers have been skipping gaskets for RTV for some time. It works perfectly well if you know how to use it. And if you already drove it home then you can keep driving it, no need to let it sit for days. There is already fluid in it now so the RTV is exposed to fluid and is doing its job of sealing already. No mechanic has time to let it sit for 24-48 hours before refilling it and getting it out of their bay.
Just trying to be super careful here...dont want any trouble...so digging deep into every step... The mechanic said it was ok to drive when I picked it up, but I felt better simply driving it back and leaving it in the driveway for the night to have peace of mind. It will be driven later on in the morning.
Mazda transmission pans are the same way. Tyey use the grey sealant as well. However, if you get the filter kit from wix, it includes a pan gasket. Go figure.
Here are the two Permatex Greys
Ultra Grey- Original formula
Optimum Grey- New formula
As someone said, this isnt that uncommon. What is uncommon is it wasnt RTV'd correctly in the first place, or it was done shoddily. Good thoughts and wishes wont keep it from leaking. Its a ford though which has racked up numerous quality complaints across the board for several decades now so I wouldn't be surprised any number of people on their assembly line was asleep at the wheel at any given time.
Not using gaskets on differential cover housings is nothing new... My first ford trucks had RTV instead of gaskets on the differentials - and this was for a '97 and '99 F150...
AS to the thick vs. thin... whatever makes you sleep better at night. Reality is there are literally millions of these things out there running the manufacturer recommended oil weights without issues.
When we get these we just order a complete front diff. Ford doesn't stock them in any warehouse and they are built to order with a 4-6 week lead time. They don't hold enough fluid stock IMHO. I think these are an 8.8" front diff (don't hold me to that) and Lube Locker makes a gasket for them.
My Honda Element was done the same way with HondaBond garbage on the oil pan and timing chain cover. I thankfully didn't have any problem that I saw, but it always had a leak coming from various sensors and solenoids. I would periodically try to make sure the oil pan bolts were snug; almost all of them were tight except a few that just budged ever so slightly. Hopefully, it stays sealed, as you have to drop the subframe on it to do the job. I am never a fan of just RTV on diffs and such, but it is what it is sometimes.
If you google "Ford F150 front differential" there are a lot of issues that can be found. This part will be on my watch&monitor list.
In hindsight I should have left the 2023.Navigator at the first independent mechanic and paid out of pocket. That guy seemed to zero in on the issues real quick and knew the Ford truck line. This time around Im sidestepping the dealer and hopefully this works out.
I also learned my current dealer is no good and started a conversation with another one.
At this point I did everything I could do. Thicker, better gear oil. Best RTV on the market. etc...
Why is it garbage? I like it.
I prefer a gasket vs RTV on all my seals. After I bought the Honda, I saw the RTV has a high leak rate, and no type of high mileage oil will help slow the leak. I have read, I believe on here, can't remember exactly, that high mileage oil can be counter productive for leaks that used rtv. Not a fan of dropping the subframe. Plus I worry about leaving rtv bits inside when removing and cleaning the surfaces up.
My one example, is my John Deere riding mower. The Kawasaki valve cover does not have a valve cover seal that I or the local dealer can find. I have used RTV Ultra black and Right Stuff 3 times on this valve cover and she still leaks. I have left it sit on ramps for 24hrs everytime and cannot get it to seal properly. Made sure everything was oil free with multiple cleanings before use and no luck. Another example, I had my mechanic do my rear diff on one of my trucks, after a surgery couldn't do it myself, he uses rtv and after a year it had leak, everytime I use a gasket I get zero leaks for many many years. I get that time is money and it cant sit empty long enough sometimes.
My examples of why I personally think gaskets are better. I know gaskets can and do leak but sometimes you can buy time with High Mileage oils
It's obvious you haven't worked on a lot of solid axle vehicles. Guess what, the rear differential cover on your truck is also sealed with RTV, as are a myriad of other gaskets on every vehicle (valve cover gasket cam plugs, differentials, Ford's 2.7l eco oil pan, mazda oil pans, etc.). I tried a fel-pro gasket on my rear differential the first time I changed it and it leaked. Resealed with RTV, no leak. The only gasket I would use on a differential would be a lube locker. Just changed the fluid on my front diff last weekend...sucked it out and refilled through the fill hole so as not to disturb the, OMG, factory RTV. 9 years without a leak on the same ford 8.8.
Changed a lot of diff fluid and prefer to open them and check for metal. Except the stupid front diff on my old Expedition that had no way of opening it up except for dropping the axle, so let it be. My preference are gaskets and they work well me, good for you and rvt. Doesn't mean I am right and are wrong or vice versa, just preferences. And guess what the world goes round and life moves on. I didn't put your preference down, back off. I just gave 2 recent examples out of many i have done over the last many years. And No both my trucks, c1500 and f350 have gaskets. So did my previous 2 dakotas , c1500, and other rwd vehicles over the years.
I honestly feel it is the manufacturers cheapening out production vs what is better in the long run.
If true I've recently slapped several Lube Locker copies in '04-08 Ford front diffs.
https://www.amazon.com/dp/B07Z8X85G1
There are many leak recalls due to RTV, and many folks that just have to foot the bill to have a reseal done on engines, or ? that RTV was used on. Way over rated stuff, and super difficult to properly clean off any soft aluminum, iron a bit easier.
All that is needed is a good search on the many leakage stories of RTV. And even the so called experts on the u tube always use way too much I can imagine the amount that falls in and can plug things up. From the factory some subaru's were being destroyed because of it.
Just an update. The fix is holding very well.
As for thickness/viscosity of the gear oil I believe 75w85 is the thinnest gear oil sold on the mass market. Just about any other gear oil is thicker. 75w-90 is a popular replacement choice. On the Amsoil website they have a data sheet comparing the viscosities.
Since Ive had problems with Ford differentials I went with 75w-140 and not looking back.
I looked into it and there are Ford differential assemblies in stock and $1500 at an independent mechanic will take care of it. Back in 2023 they were on national backorder.
