Did Subaru resolve the excessive RTV on the BRZ ?
FL
I’ve seen videos of Subaru BRZ with excessive RTV and clogging the oil pickup tube and engine damage under 10K miles.
I was thinking about buying a BRZ.
It was an issue with the older FA20 engines, and it's still an issue with the FA24 engines on the 2022+ BRZ, unless they've made recent manufacturing improvements I'm unaware of.
For the FA24, instead of addressing the root cause of the RTV issue, Subaru decided to change the design of the oil pickup screen. It has a box-type design now, and the RTV typically just plugs up one of the four sides. This is an improvement, but if you were to buy one of these cars, I'd plan to inspect the screen at least once after break-in.
The FA24 does suffer from oil pressure drops in right-hand turns on certain racetracks, which has caused bearing failures, but this is largely unrelated to the RTV. It seems to be related to the offset position of the oil pickup in the sump, combined with the poor oil drainage from the heads and timing cover that's inherent to the boxer engine configuration. If you don't track the car and you mind your oil level, I wouldn't be too concerned about this issue though.
Between RTV and oil pressure issues, one has to wonder about overall engineering.
It is to me that someone advertises a vehicle as track-ready for that crowd and has issues like that.
I understand why manufacturers use this crap, automated application, inexpensive and so on but they have gone over the top with it.
On the Subaru engines it can main bearing clearance and plugs up the main oil galley yet they continue to use it when in fact there is absolutely no need.
