P0420 code after Protect and Restore
All emission readiness tests have completed including catalytic converter, which cleared the permanent P0420 code. The pending and confirmed P0420 codes have not come back since they were erased. I'll probably use Cataclean again right before a planned trip to Maine. Since my wife drives so many short trips with the car, I'm going to use it once a week for a highway trip I normally make in my car, a 2007 Accord V-6 manual 6 speed coupe which consumes no oil. Going to try 5w30 Restore and Protect in the TSX to see if oil consumption decreases over the summer. VTEC actuator on the TSX can rattle on startup when the temps are in the low 20's, so I'll probably run 0w20 in the winter.
I don't see how anything you pour into the gas tank can do anything for post exhaust manifold? Special fumes?
I'd guess weak O2 but you didn't show any voltage values. It's helpful to see the highs and lows values and the frequency in which they cycle. The post ac at one should normally not cycle much with constant throttle. Closed throttle it should drop out but bad cat and it will be eerily similar to the cycle of the primary O2 sensor.
Go to their website. They explain how it's supposed to work.
https://cataclean.com/how-it-works/
This is a mysterious code and I always wondered how an ecu throws it. Is it cumulative, or instantaneous (the efficiency deficiency). The problem with this code is dealers tend to throw the baby out with the bath water and replace cats and 02 sensors which is expensive.
We have a GM where if codes are erased it can take 1,200+ miles for the evap to be ready. This code makes people want a new car 😡
I received a notice from Acura soon after purchasing a 2011 Acura TSX Wagon, warning about oil consumption, extending the warranty and offering to replace the piston rings if oil consumption became excessive. They also suggested using only top tier gas and letting the car warm up before hard acceleration. Oil consumption has remained fairly constant at about 1 qt every 3k miles, so no warranty fix. I shortened OCI from the maintenance minder to 7,500 miles right away and then to 5,000. I did my last oil change using Valvoline 0w20 Protect and Restore for the first time and got a P0420 code for catalytic converter low system efficiency about a week later. I checked my oil and found that it had gone completely dark, so I drained it and put in 0w20 Kirkland. I suppose the “restore” part of the oil package loosened up a lot of carbon and I’m thinking it might have fouled the converter or sensors. I suppose the oil burning over 125,000 miles has not been good for them either. The car runs great and freeze frame at the time of the code shows a lambda of 1.009, short term fuel trim at 3.1%, and long term at -0.8 %.
I put in a bottle of Cataclean in a quarter tank of gas and drove 20 miles. Filled the tank and went on a trip of 100 miles at 70 to 80 mph, occasionally holding the transmission in 4th gear at about 3,600 rpm. No hesitation or drivability issues so converter is not clogged. Then I replaced upstream and downstream sensors with Denso, anticipating that I'd want new ones anyhow, in the event that I have to replace the catalytic converter. I cleaned the throttle plate and MAF sensor even though they looked pretty good. No evidence of exhaust or vacuum leaks and very smooth idle. I erased pending and confirmed codes, so CEL is off but permanent code is still there, because it's permanent. Fingers crossed.
replace cat and contact me for alternative to Honda expensive suggestions
The 2.4 was the only engine choice for the wagon. A lot of opinions pro and con about using a thicker oil to combat consumption. I have also been reluctant to try an engine flush out of concern for the seals. I have zero leaks and colored concrete pavers where I park.
The thicker oil is some thing you need to try and if it works good and if it doesn't it is not any difference in the cost of the oil change
Just a follow-up: CEL / P0420 never returned. No pending codes. Readiness tests all report completed. Oil consumption has not changed, still about 1qt per 3,000 miles with Valvoline Restore and Protect.
The first time we got one, it was literally Christmas day 2022. The code didn't come back for another 10 months. Reset it, didn't come back for months again. As time went by, it began to come back more regularly. Also, no rhyme nor reason. Sometimes, 1,300 miles, sometimes, 80 miles. It's the 80 that's disconcerting.
I finally learned, and contrary to what we're taught. The internet is correct. In Calif, in PA, etc., one "CAN" pass emissions with 1 readiness, not ready. Face to face? Garages told me that's not true. My thinking was it doesn't matter what Drive Clean PA says, because the garage is the one that puts the sticker on the car. It took 2024 for it to finally click--the technician is making a decision on the safety inspection, he/she is not on the emissions. The car is plugged into their computer which is linked to the Commonwealth of PA. The system makes the decision. So whether or not the garage "feels" a car will or will not pass emissions if one I/M category is not ready, is irrelevant. It's not up to them.
So this year, I simply went in with 6/7 categories ready, EVAP not ready. PASS (again the problem is our GM takes 800-1300 miles for the EVAP to be ready and by then the P0420 is back--my other car, 70-80 miles. The third car I've never reset it in 17.5 years). Just my musings on this topic, can't wait to get a new car maybe 2026 or 2027. The more we drive what we have, the easier it is to plunk down the price of a new car these days (likely six figures). P.S. also didn't realize until this year, erasing the P0420 via the Autel, or disconnecting the battery, does not clear it out of pending. Only the car can do it. I knew newer cars were like this, but didn't know our 2011 was.
It has been a year and a half and the P0420 code has not come back. I've continued with Restore and protect. I'm using a qt every 4 or 5k miles now, down from a quart every 3k. So it looks like things are headed in the right direction. Fingers crossed, as I am due for another PA emissions check in January.
Spoke too soon. The CEL with P0420 code just came on yesterday. Downstream O2 sensor is tracking the upstream. PA emission test is due in February, so I've got a factory cat on order for just under $1,000 from an online dealer (about $500 below retail). Also, I switched back to 0w20 Restore and Protect a couple of months ago just to see and consumption was back up to a qt every 3k miles when I checked this morning. So it was really just the switch to thicker 5w30 R&P that helped with consumption. Since the car's been burning oil for the past 80k miles or so, I estimate it's burned about 26 qts of oil in that time. I'm pretty sure the oil is what killed the cat. Should I be thinking about Mobil 1 ESP to protect the new one because of their claims of less sulfur, phosphorus and ash? 5w30 or maybe 0w30 for better winter startup protection? Would treatment with something like CataClean every 6 months be a good idea for delaying future problems? Again, my wife is the primary driver and lots of short trips since she retired. Car can go a couple of months without seeing 45mph unless I take it on the highway. Acura reached out in a letter and offered owners a free ring or engine replacement for this problem years ago, but required that consumption be in excess of 1qt per 1k miles. Never got near that.
