More pictures including the other side.
Pretty sure it isn't lead, i cant dig a occulting tool blade into it, it looks maybe brass it seems to have pipe dope on it, or did until i went to scraping.
Ok, so that is a 2x2x1.5x1.5'' Sanitary Cross, or double tee. It is tapped on both sides. Which is to say it is threaded.
So, if it is not lead, I am not sure what it could be......probably whatever concoction someone had.............is still think it might be lead under there.........hard to tell without being there.
With heat, you should be able to remove whatever is there, back down to the threads.................
If that does not suit your fancy, you will need to replace it with a new fitting. If it was me, I would just cut it out and replace it with new, but I am a professional.....not sure of your skill level.
One tip: secure the vent pipe solidly with wood or strap or both, to ensure that when you cut the pipe, the vertical vent pipe does not slide down.......cut the pipe under the tee first.........give yourself about 2 inches of pipe from the lowest point if possible. Above maybe 6 inches above the tee. Cut nice and easy. A slow blade will but better in metal than a fast blade.
A standard metal blade will work with the galvanized pipe, not cast iron.
List:
2x2x1.5x1.5" sanitary tee
1 foot, 2 inch pvc
1 foot, 1.5 inch pvc
2, 2'' no hub bands...... do not use Fernco all rubber bands, you are looking for bands with metal shields, tighten to 60 inch pounds, or as tight as you can get with your nutdriver by hand.....
glue and primer, or glue and some sandpaper will work
let me know if you have more questions.
doing this yourself will save you about $600.
