The built in line is very faint, your new line is great. ThanksI wonder if the dotted line I put in is more visible. It's twice as wide as the default line so it should be more obvious.
Forgot about that. Pretty sure I had it enabled with the old software. Enabled it again.... So much cleaner now !We do.
You can type the dotted line into the top line of your signature.Mine should not be confused with part of the post...
That said, not going to type a dotted line at the end of my posts because code is written poorly and you choose to continue to use it.
You mean you do not want to be able to view my latest FrankenBlend?Forgot about that. Pretty sure I had it enabled with the old software. Enabled it again.... So much cleaner now !
The correct response is "By Your Command"I will not comply.
why would I want 2 lines?You can type the dotted line into the top line of your signature.
The second line is not for you.why would I want 2 lines?
UD, click on your username in the toolbar at the top of the page and select "Preferences". In the "Style" box, choose "BITOG_Dark" from the dropdown menu. Hit "Save" button.what...? where is dark mode?
Thanks,UD, click on your username in the toolbar at the top of the page and select "Preferences". In the "Style" box, choose "BITOG_Dark" from the dropdown menu. Hit "Save" button.
Again, don't need a second line.The second line is not for you.
