Please help me find a good oil for my application
So I have decided to go with Mobil 1 ESP 5w30.
It is API SP rated, and also has the more stringent Porsche C40, MB and VW specs.
I decided to go with this one because it is low/mid saps. So should run cleaner in a TGDI engine like mine.
I know Mobil 1 recently changed the ESP formulation, but the general consensus is that it is a still a good oil as it still meets some pretty tough specs.
I decided to stick with the 5w30 spec because while I do drive the car hard sometimes, it doesn’t see the race track. At least not yet. And my oil temps don’t get very high. And the ESP 5w30 is on the thicker side for a 5w30. It is a much better option than the 5w30 API SP-RC oils that are just too thin for a high performance application in my opinion.
If anyone has a better option for my modified TGDI engine, please feel free to chime in and let me know. My car is currently tuned to about 300hp and 400ft/lb at the wheels.
Just keep in mind the ESP 0w30 that is on shelves is not API SP like their online docs claim. Make sure the 5w30 is....
I would love to run Mobil 1 0w40 it’s a very stout oil for a high performance application.
It is a high saps oil though. And some are saying not the best choice for TGDI. But I don’t know if I buy into that.
High saps might create more intake valve deposits possibly? I’m not sure.
I know the new formula of Mobil 1 0w40 is API SP rated. So that is a plus to help with LSPI
Plenty of boosted DI 4-bangers running high SAPS Euro xW40s without higher levels of intake valve deposits or LSPI issues. I think this is a bit of a boogie man. Just about every tuned-to-the-moon VW GTDI is running this stuff.
These engines don’t burn much oil.
But they do have high crankcase pressure and blow by through the PCV system.
Like all boosted high-performance 4 bangers. Your carbon/gunk intake valve build up is more of a function of how efficienty the oil/air separator in the PCV is than the type of oil you run.
**** now I’m back on debating Mobil 1 FS 0w40 vs the ESP 5w30 lol.
Both oils would be a good choice correct?
Would the full saps 0w40 offer more protection or any benefits over the ESP?
Is Porsche A40 better than C40?
If you have a catch can, you can get an idea of how much oil goes through the PCV system. I found that my 3.5EB moves about 0.75-1 oz of oil through the PCV every oil change during the summer. However, in winter, I found that the system collects roughly 1oz of oily emulsified snot per 1k miles. YMMV, I'm using HPL's No VII 5w30 Euro offering now and have no worries.
I think either is fine with the 40 grade providing marginally more protection I believe but this is splitting hairs and depends on your use case. Tracking it?
I don’t buy into the catch can stuff. And my tuner advised against altering the PCV system. I can’t deny that the catch cans do catch something though. The catch cans might slow down IVD but won’t stop the problem. If I ever have any issues with IVD I suppose I’ll just clean the valves.
No track use yet. But maybe in the future.
A killer bit of data on the VW EA888.3's PCV by a buddy of mine. TLDR - catch can generates it's own volume...most of the oil in that PCV drains back to the crankcase, not to the turbo inlet making these nearly worthless unless you run the plate in place of the factory PCV that blocks the intake port drain back path which also increases crankcase pressure under low/no-boost conditions which is bad.
https://docs.google.com/document/d/1kT0dL-k1hoEbZGsy6vQBs2-pHTWXO4dQ3QBrFMqcwD4/edit?usp=sharing
Hmm, maybe show this to your tuner:
https://bobistheoilguy.com/forums/attachments/17ff6f93-1bf0-43c9-b0d9-d68cb3cfc01a-jpeg.139010/
https://bobistheoilguy.com/forums/t...-of-time-and-money-stop-in-for-a-look.365092/
Yeah that’s pretty much what my tuner said. He said these ecoboost don’t have the issues some older gen TGDI had and that IVD and LSPI weren’t of much concern. And that if the PCV system is functioning properly than I will be fine and that no catch can is needed.
Don't run a catch can - as you say, if factory PCV is doing it's job it's completely unnecessary.
