The only way to answer your question is by knowing how you drive it. Do you run the poor little thing at redline and try to set new 0-100 records constantly?
Spirited to you might be 'holy chit - slow down you animal' for me. I drive my F150 fast, often running at 85-90 - but I don't romp on it to get there. I pass people running 5 over on 2 lane highways frequently, sometimes I pick off 3 in a row. That often requires me to stomp the snot out of it and it kicks down pretty far. That's not spirited, but some folks might think it is.
As someone mentioned above, you are a grade over and that's probably more than enough. PUP is good stuff. It might start out a little on the low end of 5-30's and it might shear a little, but it's still going to be more like a 5-25 - which is still a little over grade.
Buy the majick oil or buy the regular top shelf oil - all are excellent. Change it every 5k if you are really more like an animal on the pedal, or at 7k if you really aren't dogging the slop out of it.
