Piston Soak time for the SL2
Well, I extended this procedure a little 🤣
I got out the last stubborn bit with folded/twisted up paper towels
Put in new copper NGK V-Power spark plugs, drained the oil, replaced the filter with a Supertech MP3614 and put in a couple quarts of Mobil Super 5000, some Quaker State Higher Mileage Engine (w/SLICK50) and some MMO.
Held my breath and started the engine. It was a no go for a couple minutes. I was becoming a wee bit concerned, but eventually it fired up and I kept the idle around 2k for about 10 minutes entertaining the neighborhood 😄
Bit of a smoke show.
I let it idle for a full 20 minutes
Then I replaced the Supertech filter
again. Yes, you will see a filter's innards with zero miles + a 20 minute idle after a piston soak, using fresh oil.
I used a gallon of Delvac 1300 after the idle flush.
Put a bottle of Gumout Expert Series Regane Complete Fuel System Cleaner in the gas tank.
Is that a motor oil? Wouldn’t the viscosity be kinda high to make it past the rings and slow cleaning? If I ever do another flush, I’ll use some premix as a last step.
No, HPL Engine Cleaner is not a motor oil but an engine cleaning fluid of about 20-30 grade.
I made a rookie mistake and took a drive on residential (25-30 mph) roads
After several miles the car ran real rough at idle, I had to hit neutral and do some feathering to keep it running.
I got it on the interstate for a good long while including a 10 mile stretch with OD lockout to blow all the carbon out. Lesson learned. All good now.
I see no issue with trying a piston soak. But having torn down and rebuilt a Saturn s engine, and owning several, I don't see it working.
I've tried it.
With the rebuilds I did, I found the low tension rings oil rings really lost tension. The first and second rings were good , so it had good compression, yet burned a lot of oil cleanly.
Those Saturns were some of the only cars that got the mpg that was on the sticker.
My son's sc1 manual would get 39-40 hwy with the A/C off.
I've tried it.
I have had several 40 mpg tanks on highway trips on both my '99 and my old '93 SL2 automagic S-Series
🍿 Thanks for posting. I miss our two SL2s. I occasionally think about searching for another.
Also didn’t realize saturnfans was gone :(
Has anyone figured out a way to not destroy the neighborhood with smoke on restart?
I did this a few years back with a Jeep 4.0 with 240k on it. The smoke screen was a disaster. And it kept coming. It was so bad I drove out of the neighborhood. But that was even worse… there was no wind - it was a dead still Saturday morning, and I filled the street, including a 4 way intersection, with a complete smoke screen - you couldn’t see ANYTHING for 5 minutes. I was so scared there might be a wreck, but thankfully it was early enough that by grace nobody happened to drive through there.
If I were to do this again, I’ve wondered if there’s a safer way? Send the exhaust through a hose to a bucket of water? Like how boat exhaust goes through the prop? Something? It was BAD. ideas?
just send it imo.
if ya cant take the smoke get off the road
you ought to see the smoke screen when i start my 8v92 detroit on a winter morning. neighbors of the warehouse have called the fire dept. on 3 occasions.
