Piston Soak time for the SL2
It's only been 179 miles since the oil change and I am not noticing usage yet. Before, it was using @ ~1000 miles to the quart. Too soon to conclude success but looks good. I am using Delvac 1300 so that is a factor.
Might be interesting to try the valvoline restore and protect. Its not in a 40wt though.
Has anyone figured out a way to not destroy the neighborhood with smoke on restart?
I did this a few years back with a Jeep 4.0 with 240k on it. The smoke screen was a disaster. And it kept coming. It was so bad I drove out of the neighborhood. But that was even worse… there was no wind - it was a dead still Saturday morning, and I filled the street, including a 4 way intersection, with a complete smoke screen - you couldn’t see ANYTHING for 5 minutes. I was so scared there might be a wreck, but thankfully it was early enough that by grace nobody happened to drive through there.
If I were to do this again, I’ve wondered if there’s a safer way? Send the exhaust through a hose to a bucket of water? Like how boat exhaust goes through the prop? Something? It was BAD. ideas
On my B-12 soak, avoided big smoke by separating the wash.
Drained used oil into new clean container, then collected whatever B-12 wash mixture separately in an older container. After soaking done and confirming cylinders dry, refill used oil, added a small amount of MMO to re-lube the rings. The startup smoke minimal as if mainly MMO burning off.
Sharing pics of the drip brew evaporated about a day
Thank you for sharing, good tips.
My soak seems to be a success. I put in a gallon of Delvac 1300 with a Supertech 3614 which put the level past the crosshatch and covering FUL of FULL lettering beyond the crosshatch.
I am at mile 640 and it now covers FU of FULL
Very significant improvement from previous 1k miles per quart
I'll credit @Cujet on the plug out idea in this thread:
https://bobistheoilguy.com/forums/threads/new-to-me-piston-soak-technique.332470/post-5540109
Your filter cutting + photography is top notch.
I am now at 901 miles and there is some apparent usage now. I fished out a liter of ECO-nergy I got for free on Amazon for the usual reasons 🤣. I put in one cup. Later I'll check the dipstick after a drive. If the level is the same as at mile zero, then that will be 3000+ miles per quart.
I’m currently doing a sequential piston soak with my Scion. When I did it to my first one I did all four cylinders at once with the drain plug out. That made it really hard to start with all pistons not sealing well, even when I added some TCW3 two stroke oil.
This time I’m doing one cylinder at a time with the oil still in. I’m letting it soak 24 hours, then vacuuming out any remaining fluid and starting it and letting it run a couple of minutes before doing the next one. No idea if it will make a real difference but it’s certainly easier on the starter.
