Pennzoil Ultra??
NC
Guys I bought a 5qt jug from walmart today and noticed it was API SN. The qt bottles are API SM which is the better?? May I say whice is newer?? I did not notice it until I got home I was going to service my truck but I wanted to keep the same oil type should I go back and fine some SN ??
My current fill of PU in the Suzuki is API SN...previous fill was SM (which produced a phenomenal UOA over a 5,000+ mile run). From what I understand, there are some changes (lower calcium and moly) to the newer formula but preliminary UOA results appear just as good...use the SN stuff with confidence (the SM will eventually be gone as it's being replaced with the SN).
SN is the newest spec so the sm is older, most likely been in stock longer. Eventually all sm oils left on the shelf will be gone as they sell off. Either one will be fine it's not worth the difference to go back and retrieve the sm spec oil.
Thanks! for the info guys. I did notice that the SM was not FORD WSS-M2C945 it was WSS-M2C930 and the owner manual said use 5W-20 FORD WSS-M2C945?
Use either one with confidence. The SN version appears to be really high quality, even compared to the SM.
Originally Posted By: DemoFly
http://www.pzlhittheroad.com/
Thanks for the link. I might have to pick some up. $17 for a 5qt jug of PU after rebate seems like a pretty good buy IMO
if you still have the receipt you can go on pennzoil's website and get a $10 shell gas card.
On second thought.....
If I am reading the rebate correctly, it only applies to oil changes done at a quick lube place correct? As a DIYer we cannot get the rebate for buying 5qts of oil?
