deven: The important things to compare are: the gasket 2.475" dia.; the bypass pres. 8-10psi,; and thread size 5x20MM. I have used any of the following on my honda's. Wix 51344, 51334 or 51356. Take away the first didgit (5) to cross to NAPA Gold numbers. These are all larger diameter, (except 51356 ) than the small 7317 filter. The purolater L 14610 (Wix 51356 ) is a good choice if you can use only the small diameter. The Wix web site offers much information that is helpful.---Old tommy
