Originally Posted by PowerSurge
Incorrect. There never was a government forced recall. And Toyota issued a "safety recall" in 2009, well before the class action lawsuit in 2015.
I never said the government forced the recall, I said there was a class action lawsuit, which there was.
Do you have the text of the 2009 Safety Recall? The CAL was launched in 2014 and for the 2005-2010 Tacoma, 2007-2008 Tundra and the 2005-2008 Sequoia.
The original frame Service Campaign, covering a limited number of vehicles, was launched in 2014, the same year as the Class Action Lawsuit, and was later updated in April of 2015:
https://static.nhtsa.gov/odi/tsbs/2015/MC-10111381-9999.pdf
Toyota then settled the Class Action Lawsuit in 2017:
https://static.nhtsa.gov/odi/tsbs/2019/MC-10154786-9999.pdf
Originally Posted by Toyota
Dealer Package: Modified warranty claim submission flowchart. See Appendix A. In our continuing efforts to ensure the best in customer satisfaction, Toyota is announcing a Warranty Enhancement Program to extend the warranty coverage for Frame Corrosion on certain 2005 - 2010 model year Tacoma vehicles. On May 21, 2017, a settlement of claims in a class action lawsuit involving 2005 - 2010 Toyota Tacoma vehicles regarding frame corrosion was approved. This finally approved class action settlement includes inspection of the customer's frame, and if the frames meet or exceed the Rust Perforation Standard based on the Court-ordered inspection criteria, the frame will be replaced at no cost to the customer. This settlement will also include CRC (Corrosion Resistant Compound) application.
2009. Not 2014.
https://news.pickuptrucks.com/2009/...pickups-for-frame-corrosion-problem.html
That's not the frame recall, that's the rear crossmember recall for the previous body style Tundra, 2000-2003, which wasn't in the CAL, the years of which you can see in my post above.
The article states:
Quote
Toyota and the National Highway Traffic Safety Administration have announced that Toyota will recall approximately 110,000 Tundra pickup trucks from the 2000 to 2003 model years in 20 cold-weather states and the District of Columbia to fix a frame rust and corrosion problem
that could cause the spare tire to fall away from the truck.
It then states:
Quote
Beginning in Dec. 2009 through early 2010, owners of the involved vehicles will receive a Safety Recall notification via first class mail asking them to take their vehicles to a Toyota dealer for an initial inspection of the rear cross member. During this inspection, the rear cross-member including the surrounding components such as the brake line at the proportioning valve (which is mounted on the cross-member assembly) will also be inspected. Based upon the inspection, Toyota will do one of the following at no charge:
If there is no significant corrosion of the rear cross-member assembly or the rear brake line at the proportioning valve, owners will be notified of that fact and requested to subsequently bring their vehicle back to the dealership
so that a corrosion-resistant compound can be applied to the rear cross-member. Toyota will notify the owner when the corrosion-resistant compound is available.
or
If significant corrosion is detected such that the rear cross-member can no longer safely support the spare tire and replacement components are available,
the cross- member assembly will be replaced.
So no, the frame replacement campaign didn't start in 2009, it was 2014 from what I can see.
