Originally Posted By: peterdes
Same as I have been saying. The thin oils may be suitable for the camry mall cruiser, but not for more high performance applications.
So tell me, before this gets away: exactly why do you feel the need to use pejorative terms like "camry mall cruiser" in your argument. Could it be that, having no solid factual basis, you feel the need to resort to name-calling instead?
If, by "high performance application" you mean engines involved in some form of racing, then sure. As I've been saying all along, you have to look at the specifics of the situation. For the vast majority of street cars, be they Camrys, Tauri, Accords, Mustangs, or whatever, a 20 wt oil is providing optimal lubrication. A top fuel dragster is a totally different animal. If you want to consider different animals, consider for example, Mobil Jet Engine oil -- which weighs in at about 5 cSt -- and where are all the jet engines that must be coming apart? I hesitated to offer that example, because I know it will get all of you hootin' and hollerin' that it's not a fair comparison, and you know what -- it isn't. But in like fashion, comparing a top fuel dragster (or virtually any car that's only a racer), to any street car, is similarly not a fair comparison.
Also, the argument that if thin oil destroyed engines, then there would be many modern cars in the junk yards is getting quite old.
It's getting "old" for you because you simply have no good answer for it, and it simply doesn't square with
your opinions that you wish were facts, and that you want to hold on to. You will continue to hear this point until someone proves (not with "one-zee" and "two-zee" anecdotes) that there actually is damage being done. Not destruction, just damage.
No ONE is saying that thin oils destroy engines. Only that thin oils may not be providing the best protection...
First off, well yes, many of you have said that. Go back and review the evolution of the thick-thin threads. At first, for many, it was all about destruction. As recent history has proven this to be wrong, it has slowly shifted to "optimum lubrication". Perhaps true for some applications, but I'm confident that as time marches along, we'll see that for most modern engines, lighter oils actually are a better overall solution.
And finally, you simply can't have it both ways. Either the oil is protecting the engine, or it's not. Now the syrup worshipers are suggesting, through the "not optimal" theory that some damage is being done, but that damage conveniently escapes all the normal means of measuring such. If 20 wt oils were actually causing more wear in engines, then we would see at least
some objective indicators, such as lead and iron, etc., consistently being elevated above comparable cars using heavier oils. But we're not... Most of the studies are tantalizing (in both directions), but they simply don't tell us what's happening in the bearings of an average, street-use Accord or Taurus.
It isn't that complicated.. But obviously, for some, it is.
If you're wondering who "some" might be, check a mirror.
