OVERKILL ..can you show me one study that Doug has done on a Ford Escort with a low compression 1.9 engine living a normal life? Honda Civic? Geo Metro? Prius?
Every instance that I can recall, Doug has been on the leading edge of high performance R&D and HEAVY DUTY R&D.
When have you heard him comment on something that didn't spec AT LEAST a 40 grade from the OEM?
This is not at all meant to discount anything Doug says ..since I'm absolutely sure that it's GOLD ..but there's is a whole lot I've never seen him say (I can't hear him, but I can imagine it) ..since ..to tell you the truth, it's of no interest to him. I've never heard him comment on the mundane. That's just about our entire existence for most of us.
We talked about my Expedition. There's a thread on it here somewhere.
I'm glad he gave a token mention to a light weight oiled engine
This has been fun, as usual - in a +/- way
I would never argue with XS650 ...Doug Hillary ...and someone like Shannow. They're too smart. The only trump card that anyone in the lighter persuasion camp has ..perhaps it's more of a rhetorical trick up their sleeve, is that we're waiting with anticipation for the legions of grenaded and tired 20 weight engine to show up. Those who have been waiting ..well, they've been waiting.
It's kinda like Poole and Bowman pulling the control module from the main antenna array on Discovery due to HAL's 100% flawless determination that it was going to fail in xxhours. Poole and Bowman find nothing wrong with the thing.
We never got to see that test played out ..
Anyway ..since we're not seeing all these grenaded and degraded engines .........AND the physics are allegedly immutable ..the conditions of the real world testing MUST be different than normal givens. That is, assumed conditions just aren't realistic or factual.
I know for sure that I have never stated that engines would grenade or become prematurely tired running 20-weight oils. In fact, as has already been discussed in great length, the older 30-grades used to readily sheer to a 20-grade anyways.
My only argument is that a heavier oil will provide better protection. I don't think in a lower-HP Ford Modular application, that the extra protection is needed. That is why the engines will rack up obscene mileage on these oils. The bottom-ends are over-built and incredibly rigid, and with the somewhat mediocre BHP they produce stock, and with the low-operating RPM range, a light-oil provides better fuel economy and more than adequate protection.
In the high-HP applications, Ford calls for heavier oil. The reason for this to me seems to be a no-brainer: The intended use is much more akin to ABUSE, and the much higher BHP out of the same displacement means much greater stress on the bottom-end. The heavier oil offers better protection under these circumstances.
The OEM's wouldn't spec a lighter oil if it was going to cause engine failure or noticeable premature wear. On the other hand, the fact that in countries where CAFE isn't applicable, that they spec a heavier oil, means that many of the arguments about being ONLY able to run a light oil are invalid. I bring up the Ford Modular engines again for this example.
If there was a 0w20 or 0w30/5w20 or 5w30 that was built like Mobil 1 Turbo Diesel Truck / Delvac 1 5w40, I would definitely give it a run. Viscosity was not my main reason for the choice of that oil, though I do believe it plays a role in the oil's performance, which we know is exceptional.
The recent threads about Redline have me thinking about that. And our own little discussion about SSO a while back as well.
I chose this lubricant because of Doug's extensive experience with it. Slammds15 on here has been running it in his Super Duty and the cleaning it did was unreal. This sort of real-world experience, complete with tear-down testing (had to throw that in there
) are the factors that molded my choice.
In BuickGN's thread, there is mention of a 1,000HP LT-1 with fantastic tear-down results running Redline. When that sort of information is provided, I am all ears.
