Originally Posted By: CATERHAM
I'll give an example.
The Idemitsu SM 0W-20 has a 200 VI, the Nippon Oil made Toyota 0W-20 a 214 VI and Sustina 0W-20 a 229 VI. All three oils have the same 2.6cP HTHSV @150C but the Toyota oil is lighter at normal operating temp's than the lower VI Idemitsu oil and the very high VI Sustina is lighter than the Toyota oil.
I'm running the Sustina oil but I want to maintain the same hot operational viscosity as the Idemitsu oil. To do so I've had to increase the HTHSV to approximately 2.75cP (by adding just over 10% of Sustina 0W-50). The end result is that I have an oil that is still lighter on start-up to the other two oils although I'm running a higher HTHSV rated oil; the best of both worlds.
So if I understand this correctly, you've used a higher VI oil to give yourself more headroom.
Very clever application of the technology.
I guess it means that as the Japanese go thinner, they also increase their VI which increases their headroom.
