Originally Posted By: BuickGN
Where's the article that stated that increasing the HTHS up to something crazy like 11 or 16 reduced wear with each increase...
I'm sure that such a substance would run just beautifully in an Accord or Camry...
And come on guys with this whole thing about bearings and cylinders hanging on till the oil pressure arrives. Oil pressure isn't more than half a second behind the first revolution of the crank.
Is it? Always? Well, if you assume that everything is optimum, and you have an engine that idles at ~800 rpm, and it's of course starting from zero rpms, and using your 1/2 sec assumption, then by my rough calculations, the engine will experience a couple dozen or so revolutions without oil pressure. Not disastrous, but certainly enough to raise the specter of wear happening on start. Particularly when considered on a cumulative basis.
I would neither over-minimizing, nor overdramatize, this phenomenon. Again, why would the Toyota engineers felt it necessary to have the hybrids pre-oil themselves on start? Why are pre-oilers for sale?
