Originally Posted By: dnewton3
Regarding your last point, I agree overall, but I'll point out this ...
The pump relief is typically a linear progression spring device not unlike the valve in the filter. I've not known any pump relief to be an "on/off" switch with a high/low setting. They will bleed off pressure as it builds, in a variable response to the overage. Like the filter bypass valve, it will first crack open, then bleed more as the pressure increases. It's not like the pump relief opens and then 100% of the pressure is bled to the sump, while the engine gets zero. Rather,
it only bleeds off the excess pressure , keeping the engine satisfied.
Agreed ... if I somehow gave the impression it was on "on or off" valve it wasn't meant that way.
So, in my example above, when the filter media is totally blocked at it's bypass open, the pump will supply enough pressure and volume regardless, even if it is in relief to some degree.
True ... however, if the opening in the filter's bypass valve was somewhat restrictive and had to take 100% of the flow from the oil pump, it may cause the oil pump to hit pressure bypass sooner (especially with viscous oil and/or high revs), and thereby decrease the total volume of oil delivered to the engine. That's because if the oil pump hits pressure relief sooner due to higher down steam resistance, then the flow volume has to also decrease due to the laws of fluid flow in a pressurized source of flow - which is what's going on when the oil pump has been limited to a constant, max pressure.
I would agree that there is some portion of unknown risk whereas the filter bypass hole may not be large enough for a total-meltdown stupidly ignored condition (filter NEVER changed, totally blinded media, and full revs at cold start with 15w-40 in a gasser in Alaska in winter ....). But then again, how many BITOGers get into that condition anyway?
Reminds me of an indecent I say many years ago. Some drunk guy came out of a bar and fired up his old pick-up truck on a cold winter evening when it was about 0 degrees F outside. A few seconds after the engine started he basically revved the engine to near red line for 5+ minutes straight. He probably thought he could get heat in the cabin faster that way.
