Originally Posted By: Shannow
Take Larry's measured figures at
6,000RPM, and assume Mr Honda's squirters are 1.0mm dia.
Oils are considered at 100C, as that's what the KV is on the data sheet.
30W - 60 psi - Mobil 1 Advanced Fuel Economy
40W - 84 psi - M 4T 10W40
50W - 90 psi. - M 4T 15W50
Flow Rate through each squirter in litres per minute (using Benoulli's equation)
30W at 60 psi - 4.6 l/min
40W at 84 psi - 5.4 l/min
50W at 90 psi - 5.6 l/min
All at pump relief (99psi)...5.9l/s
Now the piston cooling is clearly dependent on piston cooling squirter flow, so by choosing an oil simply because you don't want flow through the pump relief means nearly a 20% reduction in piston squirter flow in the mid range....simple physics.
But you'll bring up molasses and water again...
That's where Reynolds' Number Correction comes in, and again, I'll point you back to my discussion on the operation of squirters, having a larger diameter section before the nozzle, so that the orifice, pressure, and density are controlling the squirter flow, not the viscous effects of the fluid.
For the three oils and pressure, Re
30W - Re is 940
40W - Re is 760
50W - Re is 640
D2/D1 is the ratio of the hole to the feed pipe.
Clearly, the smaller the number (bigger feed for smaller orifice), the flatter the curve is in the range of Re's that we are talking for a piston squirter.
In the range of 0.5 (hole half feed pipe diameter), to 0.1 (hole 1/10 of pipe diameter) there's SFA difference (and you can see that the thinner viscosity is actually choked a little more (flows less) than the thicker oils around the 600 mark)...not enough to write home about
Again, if you are lubing your engine with Mollasses, and your mate is running water in his, YMMV, but engine oils at operating temperature aren't molasses versus water, whatever strawman you are trying to create.
Thanks for this Shannow. Intersting calculations - I had wondered myself about flow through jets and pressure vs. viscosity.
One additional note is that sometimes there is a check valve in the path for a piston oil squirter. I've seen anywhere from 10-20 psi to 50 psi before the check valve even allows oil to get to the jet.
