Originally Posted By: BusyLittleShop
Originally Posted By: 02SE
You scoffed at my real life experiences with using a lower viscosity oil in a wet-sump bike
I did... I still don't believe your Land Speed Record Turbo Suzuki making approx. 3 times
the horsepower of the AMA Superbike should serve as a guide for an owner looking to drop
from a 50 to a 40 like you did... if you fretted gears dropping 3 cSt in oil viscosity
going from a 50 to a 40 then you're on the ragged edge of durability to begin with...
Who said we went from a 50 to a 40? I never said that. It was a 30 weight oil that was recommended by a then Yoshimura AMA Superbike crew member.
Now an old RC45 which makes around 100 rwhp, isn't a particularly highly stressed engine. Certainly nowhere near the stress they were subjected to in WSBK tune. Where rebuilding the engines after a few races at most, was the norm. In your low-stress streetbike application, you're getting away with running a 30 weight oil. Not everyone has a bike in such a mild tune, that they can run a 30 weight oil without issues.
Mr.RC45 is a 21 year old 750 but he's not old hat... he'll dyno a respectful 116RWHP in
his stock state of tune however HRC never quit lowering internal drag (30 weight oil) and
upping the power and according to my friend Al Ludington Honda's gear box never suffered
gear fretting...
Is that 116 rwhp reading a quick-sweep, inertia dyno, Dynojet STD HP figure? All based on the Dynojet Founder wanting an original Vmax to show 120rwhp? thus creating hype for his then-new Dyno? When the actual true RWHP figure when measured on an accurate Eddy Current Dyno for an '85 stock Vmax is more like 90 rwhp.
The bottom line is comparing Dyno readings from one dyno to the next, is pointless. Different brands, types, and even the operator of inertia-type Dyno's can affect the power output reading, not to mention which HP scale is being used.
As for Al Ludington's comment on gearbox longevity at mid 90's AMA Superbike power levels, how often was the gearbox replaced?
Knowing more then a few people that were a part of AMA Superbike teams, back in it's heyday. On the Factory teams, Gearboxes were replaced every race. Because as anyone involved in Professional racing knows, metal fatigues, and will eventually fail. The parts were made as light as possible, to where they were just strong enough to last long enough to ideally make it through one race, and then be replaced.
So racing parts replacement intervals, really aren't applicable to stock streetbike parts longevity.
gear fretting...
