I usually use Amsoil (where applicable) and their recommendation for both engines is 0W-20 (Signature).
Subaru specifies 0W-20, but I've heard that these engines can experience fuel contamination and high oil consumption. The particular vehicle has around 45k kms and is not using oil.
Honda specifies 0W-20. This vehicle has around 50k kms and is not using any oil.
Both vehicles are driven in the Vancouver, BC area. Typical lowest temperature is around -10C. Typical highest temperature is around 35C.
Should I go with 0W-20 or can I use 0W-30? Ideally, I would like to use the same oil in both.
