The engine is an 18RG, old JDM motor. This is a 1968CC 4 cylinder motor, basically stock running dual 47 mm carbs. Manual only says API, SE series motor oil. I know that most new motors oils have taken Zinc and other metals out that this engine needs. I have read that Rotella diesel oils are high in Zinc and that it would be a good oil for older engines. Thanks for any input.
