I recently rebuilt a 1995 Dodge Ram 5.2 (318) V8 magnum and put it in a 1967 Plymouth Fury III.
The motor was cleaned, hot tanked, cylinders honed, and completely rebuikt. It has the factory hydraulic roller camshaft (not an old flat tappet) and stock valvetrain. It has been converted from fuel injection to carburetor. The camshaft bearing clearances are between .001-.003in. The Connecting rod bearing clearances are between 0.0005-0.0022 in. The engine will be street driven not raced. It may see some Maryland winter driving, but I doubt much below 32 degrees. Mostly spring, summer, and fall.
What oil should I run in this application?
With it being the “newer” magnum motor and not the original engine I shouldn’t have to worry about zinc, right?
The shop manual for the 1995 5.2 called for any API SH 10w30. Essentially I should be able to run any off the shelf 10w30, right? I know the 10w30 seems to be a dying breed. Is there something newer or better that I should be running instead of the older recommended 10w30?
Thank you
Thank you
