Originally Posted by Ruturaj
Originally Posted by Gokhan
I made that comment three years ago. My knowledge, opinions, etc. evolve.
Why do you want to use 10W-30?
Base-oil quality is key for GDI in terms of IVD. You can look at the MSDS to see whether 5W-30 or 10W-30 has more PAO or GTL. Thinner base oils have lower aniline points and clean better. Thicker base oils can protect the valvetrain better. Low NOACK could be bad for GDI IVD as I said before.
I went through my manual and saw I had a few options for the oil viscosity. So I just searched 5w30 vs 10w30 and 10w30 was considered as better choice overall in most threads.
Then I personally didn't know what to look for except weather, VII, NOACK and stability when comparing these two oils for my situation.
IVD stands for intake valve deposits? I will look at MSDS and will search for PAO and GTL. Didn't know that lower NOACK is bad for GDI. I think I missed that post of yours.
Really appreciate you taking your time to respond, thank you.
Ignore those threads about 10W-30 being better than 5W-30. That's old wives' tale and there is no such thing.
Lower NOACK alone certainly doesn't help with GDI intake-valve deposits (IVD). Does it hurt? It probably does, as liquid oil spends more time on the valves before it can evaporate. Think about the spark-plug oil fouling. If the spark plugs run cold and the oil can't evaporate, they will be fouled by coked oil. There seemed to be a reverse correlation between NOACK and TEOST 33C in the Amsoil data. AAA study also found similar results for conventional vs. synthetic in TEOST 33C and MHT tests. However, it's difficult to separate the base-oil-quality effect from the NOACK effect in the latter study.
You need:
(1) The best full-synthetic base oil. Look at the MSDS's if possible. 5W-30's are usually made from better base oil than 10W-30 but this isn't always the case. If xW-20 was recommended, I would go with the PAO-based M1 EP 0W-20 but yours recommend 5W-30.
(2) Lower ash. Avoid sulfated ash over 1%, such as A3/B4 oils. Perhaps about half the IVD is ash, the rest being carbon from the coked liquid base oil (not the evaporated base oil, which quickly and cleanly burns in the combustion chamber) and EGR and exhaust particulates.
(3) SN PLUS. So that you get LSPI protection.
No matter what oil you use, you'll get some IVD in GDI engines unless there is a built-in cleaning mechanism such as dual injection.
