Oil for new 18 Stinger GT
Originally Posted by Gokhan
No worries.
Yes, I think Mobil 1 Extended Performance (Mobil 1 Extended Performance) 5w30 is the optimal choice for this engine among the current oils. It has tad bit more PAO and tad bit less VII than M1 vanilla 5w30. NOACKs are the same (about 10%). Mobil 1 Extended Performance 5w30 has a little thinner base oil than M1 vanilla 5w30.
I noted in my previous post that VW 504.00 oils go through the VW GDI intake-valve-deposit (IVD) test but unfortunately, none of them have LSPI protection or SN PLUS (they have high calcium and no magnesium). There are some great PAO-based oils with low - mid SAPS like Motul 8100 X-clean+ VW 504.00, but they are also expensive, hard to find, and lack LSPI protection.
Thanks. I would stick with Mobil 1 Extended Performance 5w30 until something better comes.
Does anyone know if there's a reason why 0W40 cannot be used but 5W40 can be used?
low-mid SAPS ACEA C3 0W40 oils are some of the best stuff for a T-GDI as the low saps will help prevent valve deposits and the 40weight and high HTHS will reduce fuel dilation
So the conclusion is if you want a higher quality oil for a TGDI use one that meets the euro standard MB 229.51, VW 50x.00/50x.00 , BMW LL-04 etc etc
ILSAC is irrelevant
Such questions have been asked on BITOG since it's formation, without a great answer ever coming about.
