What oil & interval do you all suggest for this truck? Background below. I don't mind the cost of synthetic oil and low use changes...
I have a 1992 F-150 w/ the 302 and 134k on the clock. It spends time as a ranch truck and probably doesn't run more than 3,000 per year. It was my grandfathers truck and I believe he had the oil changed w/ Havoline 10w30 an a regular basis.
I have had it a year now and have put about 5,000 miles on it running Mobil 1 10W30 Synthetic, Mobil 1 10W30 7500 and recently switched to Pennzoil HM 10W30 as it has a rear main seal leak. I have ordered Auto-RX to try, but it will take along time to hit the mileage recommendations for two clean/rinse cycles. The truck did burn a bit of the M1 Synthetic oil at first, but was also run hard towing a trailer. It has not burned any since that time. The results below are from the M1 SS 10w30 UOA - approx. 3000 miles on oil.
AL - 2
CH - 1
Iron - 16
Copper 6
Lead - 14
Tin - 1
Moly 65
Nickle - Potassium - 0
Boron - 104
Silicon - 20
Sodium - 5
Mag - 32
Phos - 669
Zinc - 764
Barium - 0
SUS Vis - 60.5
Flashpoint - 385
Fuel - Ins - .3
AL - 2
CH - 1
Iron - 16
Copper 6
Lead - 14
Tin - 1
Moly 65
Boron - 104
Silicon - 20
Sodium - 5
Mag - 32
Phos - 669
Zinc - 764
Barium - 0
SUS Vis - 60.5
Flashpoint - 385
Fuel - Ins - .3
