quote:
There is no such thing as STATIC PSID. Look up static in yer Dictionary.
Well, since you take exception to my nomenclature in this situation ..I'll forever go to the trouble to state it as "typical" or common ..or "normally". Yes, it was a dynamic situation ..but otherwise a psuedo "baseline" (yes, when the engine was running)
Please ..use something other than semantics here in discounting others assertions
quote:
Differential pressure is DP, not PSID.
Tell that to the people who manufacture differential pressure gauges. They need your help in this matter.
0-1 PSID Differential/Gage 287-1002-ND 50.09 35.91 28.47 ASCX01DN
0-5 PSID Differential/Gage 287-1003-ND 50.09 35.91 28.47 ASCX05DN
0-15 PSIA Absolute 287-1008-ND 50.09 35.91 28.47 ASCX15AN
0-15 PSID Differential/Gage 287-1009-ND 50.09 35.91 28.47 ASCX15DN
1
0-30 PSIA Absolute
0.25 ~ 4.5V SIP 4.5 ~ 16 100µSec -25°C ~ 105°C
287-1010-ND 50.09 35.91 28.47 ASCX30AN
0-30 PSID Differential/Gage 287-1011-ND 50.09 35.91 28.47 ASCX30DN
0-100 PSIA Absolute 287-1004-ND 50.09 35.91 28.47 ASCX100AN
0-100 PSID Differential/Gage 287-1005-ND 50.09 35.91 28.47 ASCX100DN
0-150 PSIA Absolute 287-1006-ND 50.09 35.91 28.47 ASCX150AN
0-150 PSID Differential/Gage
However ..many do also use the notation DP.
Your point beyond giving needlessly discounting text that has no more merit than mine??
quote:
As long as an oil pump is working correctly there will ALWAYS be a pressure drop across the filter element. The only time there is no drop is if there is no flow path downstream from the filter. In which case the pressures equalize, The relief valve opens and hopefully, the can doesn't burst and the bearings gaul
Sure ..has anyone disputed this?
quote:
Rembering how and why a relief valve works, the pump ALWAYS wants to put out a specific volume of oil. It DOES NOT CARE where that volume goes. (FYI the actual oil pump is upstream from the relief valve) The oil will move through both the relief circuit and out to the engine when the relief is activated. The volume of oil going through the filter will be a reduced amount that depends on how much is flowing through the relief circuit. BUT it is still flowing to the engine. As to how much is flowing... That depends on pump volume and the amount flowing through the relief circuit to alleviate the reason the relief opened in the first place.
So far ..I don't have any coflict with this
quote:
So unless the outlet port on your oil pump is totally blocked. Your filter is so clogged and has no bypass. And your engine is running there will always be flow to your engine.
Yep, unless you've got a fluid that has no pumpability ..I'll join in with an arm raised and a cheer...
quote:
I think this is Garys statement:
"What happens when I started the engine in these situation is that both needles swept up at the same rate (very near) ..and the down stream one just hung up at a lower pressure. If the filter was a factor before that point, one would reason that there would be a larger differential as they swept upward.
Sorry Gary but your wrong on this one. the DP is what it is. The differential between the pump side of the resistance to oil flow and the pressure on the other side of that resistance.
Now is where you run out of steam in effectively explaining the events.
The canned answer is "the DP is what it is" is not good enough. Sure the statement is obviously ..obvious ..but no detailed reasoning is behind it.
Take this event and explain it:
In all instances that the pump is in relief (evidenced by the max oil pressure being reached at idle where other situations with warmer starts or lower visc oil do not reach that max pressure (82 psi)) that this is the only time that higher differential is noted. Otherwise ...it's a normal 3-4 PSID (or DP as you seem to prefer)
How is this possible, Pete? How does a filter have a variable resistance? It doesn't ..or can't. It doesn't change between one event and the other. It is only the distinciton of having the pump in relief that accompanies this event.
So far you've given canned anwers and haven't explained this.
Why do I see up to 12 PSID when the relief is open ..but NEVER anything above the normal 3-4 when it is closed?
This is a function of the difference of, in the view of the PSID across the media, a series fluid circuit and one where the filter/engine is a subcomponent of a parallel circuit.
You're still not far enough below the surface on this here.
This is what occured ..this is the data. As flawed and sophmoric the test conditions may be, there is a decent margin of validity to my observations that doesn't require a Phd or an engineering degree to reason through ...or at least observe.
If we take your current ponderings on this ..BOTH of my observations are both correct and impossible. The 3-4 DP
is valid ..and the 7-12 DP is also valid. Yet they have no reason to change ..but they did ......................
.......and only when the relief at the pump was open.
Got anything more than dicounting rhetoric??
Again, I'm not publishing a paper ..I'm just the messenger. It's your job, should you decide to take it, to explain this stuff. These are not questions of how a pump works ..nor a bypass valve. These are questions of reactive "apparent" conditions that are altered by the mode they are in. One is a series fluid circuit of vaiable flow through a, somewhat, fixed conduit. In that mode ..the filter represents a very minor pressure drop in the total circuit with the engine. When flow is split ..this resistance has more apparent resistance ...since the circuit is no longer a series circuit.
It's a matter of defining this apparent difference that is the whole origin of this ongoing debate.
[ June 02, 2005, 11:03 AM: Message edited by: Gary Allan ]
