This is still one of the largest misconceptions on this chat board. With modern day full synthetic filtering media, a filter can have both high efficiency and low flow restriction (ie, meaning low delta-p across the media at high flow rates).
Jay (Motorking) provided delta-p data for the Ultra, and it flowed very well (slightly better than the graph for the PureOne below). There was also a long standing misconception that PureOne filters were also "flow restrictive" because they were so efficient. Purolator provided some flow vs delta-p data of the PureOne and it showed a very low delta-p even at 10 GPM of hot 5w30 viscosity oil flow. Absolutely nothing to worry about.
The misconception of "high efficiency oil filters are too flow restrictive" will never end, even though oil pushed through them is by a positive displacement oil pump so it doesn't really matter if a filter is a few more PSI delta-p restrictive than another.
