quote:
Originally posted by BOBISTHEOILGUY:
sorry wavinwane. the adbv has nothing to do with an upsidedownfilter. think about it. the left over oil is between the outside of the can and the inside filter media. if oil is able to seep out of frams media but not through the Mobil 1 filter what does that tell you about the Mobil 1 filter media, that it is one way or it is blocking the oil from passing by. since it can't be one way, then it is causing a restriction. that is why I no longer use a Mobil 1 filter, as it filters good, but I want oil in my bearings.
that also substanuatings my findings in my oil analsys with the different filters.
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=000211;p=1
there is 5 pages on this topic and each on has different oil anlysis with different things done each time. you'll have to read the whole thing and see what effected what. I even ran the engine with out a filter just to show what the filter does to the oil.
BOBISTHEOILGUY,
This is going to be a long drawn out post, & I AM NOT trying to be controversial, so please bear with me. It has always been my understanding that the purpose of an oil filter's ADBV was to prevent (at least some) oil inside the filter from draining back into the engine. If that's not it's purpose, what the heck is it there for?
Since I am not an oil filter expert, & since you have done extensive filter testing, I will list all the data available to me & hopefully you & the rest of the BITOGers can help me more clearly understand why so much oil remains inside an Mobil 1-205 filter that has been turned upside down. I DON'T think it is
totally due to excessively restrictive filter media.
My vehicle: '00 VW GTI 1.8T
current vehicle mileage: 55k
oils I use: Mobil 1 0w40 & GC
oil filter used: Mobil 1 Mobil 1-205 for the last two OCI's
driving conditions: 95% highway @70 mph - 80 miles round trip per day
I ran Mobil 1 0w40 & an Mobil 1-205 oil filter in this car from 46k to 51k miles, then drained & sent a sample to Blackstone for analysis. The wear levels were far below universal averages for my engine. Keep in mind, this is a VW TURBO. If that doesn't dispell the "Mobil 1 filters starve the engine of oil & lead to excessive wear" myth, I guess nothing will.
I somewhat agree with FilterGuy about why oil doesn't drain as quickly from an Mobil 1 filter, but I have an additional theory. The next time you guys are in an AutoZone, look into the end of an Mobil 1-205 oil filter. To my untrained eye, it looks as if the oil CAN NOT run out of the filter once it is removed from the vehicle. I can't give a detailed explanation; you'll just have to look at an Mobil 1-205 filter to see what I mean.
[ May 27, 2005, 02:55 PM: Message edited by: wavinwayne ]
