garageman402
$100 Site Donor 2026
I haven't been keeping up with his videos, but I saw this one & commented. His reply is here:
@themotoroilgeek
1 day ago
Oil filters do get better(increased efficiency at smaller micron sizes) in actual use. The principles of filtration are the same for air, oil and fuel filters. The difference you noted actually comes from the difference in how air filters and oil filters are tested. Air filters are fed test dust at a steady rate over time, so that you can measure efficiency vs loading. Unfortunately, oil filter testing begins with oil that is fully loaded and then continuously adds contaminated oil. As such, the ISO 4548-12 standard does not produce an efficiency vs loading graph. This is where you can see the initial loading of the filter creating a "dust cake" within the media that increases the efficiency of the filter for particles smaller than the absolute particle size.
This goes against everything discussed here on this forum, proven by @AscentFiltrationTesting, backed up by @ZeeOSix. I replied with evidence from this thread:
But have not received a reply. Any thoughts on his comments?
@themotoroilgeek
1 day ago
Would you all like to see ISO 4548-12 Oil Filter Lab Testing Comparison, Efficiency & Capacity, Pressure vs Flow, Bubble Point, and Burst?
