If oil filers lose efficiency when loaded in the ISO test, then there is no logical reason why they wouldn't also lose efficiency in real world use loading with debris. Of course oil filters in real use aren't typically loaded as in the ISO test, they will still lose efficiency. And as mentioned before, it's not ideal to run filters with low ISO efficiency for long OCIs because they shed more debris as they load.
It's debris loading combined with oil flow that makes an oil filter shed debris. There is a lot more force on the media from oil flow than there is on an air filter with air flow and a very small dP (like 20 in-H2O) than across an oil filter (could be up to 15+ PSI at high RPM). If the oil flow and resulting dP was super low across an oil filter it may also increase efficiency with debris loading, but that's not what happens with oil filters. There have been many here also thinking oil filters get more efficient with loading, just because air filters do. So it very well could be that LSJr also made that theoretical jump between air and oil filters. Guess we'll have to see what he comes up with, and it will be highly scrutinized, lol.
