hey all,
I need a 7317 filter for my 2014 acura rdx. I usually use microgard select which is $9.99 and has been fine for past few oil changes. I know the difference won't make a diff however the BITOGer in me got me thinking.
The micogard select on o'reillys website says
I don't have advanced auto in my area so carquest is off the table. I have wally's nearby but I stay away from Fram as of late just due to previous "light leak" thing that was going on last year. I forgot exact issue but something about the gasket or the valve
I noticed Autozone has STP Extended Life Premium Oil Filter S7317XL for $10.50
The description on the AZ website says
Furthermore, AZ also has the STP Engine Oil Filter S7317ML which is rated for 20k miles and description says premium full synthetic fiber media delivering 99.5% multi-pass efficiency, capturing contaminants as small as 25 microns. For $12.99
However I don't run my filters that long so i don't see a point in paying $2 more and getting slightly worse filtration (20 micron vs 25 micron)
Essentially wondering if its a no brainer to get the STP as it has 99% at 20 microns?
Thank you!
Thank you
- 99 percent efficiency (Laboratory Test Performance per ISO 4548-12 at 25 microns)
- Captures particles as small as 20 microns with greater than 99% efficiency
Thank you!
Thank you
